Results 1 to 10 of 15
Thread: overheating/no hot air!?
    Regular Member P-Mutton2.2's Avatar
    Aug 2009
    Frinton on sea
    Angry overheating/no hot air!?
    car (2.2DTI 53 plate 68000miles)
    temp guage up to the red, ... no hot air through vents air con or not,
    coolant level seems fine, just started today...
    All help/suggestions gratefully recieved.
    Birmingham
    Thermostat stuck (if it has one)?
    Bye bye Vec B
    - Hello Siggy!
    Mileage : 000
    Might be an air lock.
    Aug 2009
    Frinton on sea
    thanks for ideas,... any other indicators that might narrow it down? or is it gonna be off to the stealers?
    Regular Member W17GLE's Avatar
    bolton
    i was going to suggest it being an air lock. i'm not sure if the vauxhalls have a bleed valve on the block or if you have to do it from the header tank.
    winsford
    or the temp sensor, have you done anything that could cause this.
    Aug 2009
    Frinton on sea
    no,.. not that i can think of, car sat without use for about a week,.. ben used averagely/easy for last 3 days then just started overheating today...
    Mileage : 000
    Perhaps try running it with the cap off the expantion tank ( I mean keep the car stationary when doing this). It might get rid of the air lock. Put your heater controls on hot and give it a try. You might get some water over flowing, if so top it up with a water and antifreeze mix. I mix mine 50/50.
    Full Member Big Sig's Avatar
    Water pump?
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    you loosing any coolant? if so i had this on my vec b, no heat and it was in the red, one of the heater matrix pipes had split
  1. Overheating
    By Steve1974 in forum Engine & Drivetrain
    Last Post: 6th May 2013, 13:52
  2. Cdti 150 overheating
    By WHOOSH05 in forum Engine & Drivetrain
    Last Post: 29th August 2011, 11:43
  3. Overheating or not ???
    By Grahamy in forum Vectra C / Signum Car Chat
    Last Post: 28th July 2011, 19:22
  4. overheating
    By jonesey42 in forum Engine & Drivetrain
    Last Post: 20th April 2011, 12:24
  5. Car Overheating !!!
    By andythilo in forum Vectra C / Signum Car Chat
    Last Post: 10th January 2009, 17:56
vauxhall spanner light on when car overheats
signum 2.2 dti no hot air
