Thread: ECU and mpg
    Regular Member benwalters82's Avatar
    Nov 2009
    Redruth
    Trim : SXI
    Engine : 2.0DTI
    Year : 2002
    Default ECU and mpg
    I do 150 miles a day commuting (majority dual carriageway doing 70-75) but i'm only returning 43-45mpg.
    Is this a bit low?
    2.0 DTI SXI 52 plate
    Bought the car a month ago prior to which it had a new ECU fitted by non-dealer garage. Could this be affecting the mpg?
    Jun 2009
    Newark-on-Trent
    Mine is 2.2 DTI.
    If I drive normally between 70-75mph I usually get around 48-51 mpg.
    If I drive up to 70mph I can get up to 55 mpg on long journeys.
    If I drive between 80-90 mph I get around 42-46 mpg.
    Around city I get around 45 mpg.
    Mine average on all driving is around 46-47 mpg.
    Regular Member Keithy's Avatar
    Jan 2008
    Dundee
    Quote Originally Posted by Luke52 View Post
    Mine is 2.2 DTI.
    That sounds about right for me
    Nov 2009
    Redruth
    Trim : SXI
    Engine : 2.0DTI
    Year : 2002
    thought it was on low side. any idea? Ecu? to blame?
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    When was it last serviced??
    Jun 2009
    Newark-on-Trent
    It's hard to say. It might be software on ECU, but also hundreds of other reasons.
    I had a lot of problems with mine before - got it all sorted now, but it costed me a fortune.
    When you drive, does it pull completely normally or do you feel is weak? Also does it smoke when you accelerate?
    If not it might as well be normal Vectra is 1600 kg car and weaker engine might need to work harder. It would help if any 2.0 DTI owners would let you know how theirs are doing.
    Nov 2009
    Redruth
    Trim : SXI
    Engine : 2.0DTI
    Year : 2002
    Re : Service - based on the other problems i've had on the car (http://www.vectra-c.com/forum/showthread.php?t=94880) not for a long time.
    When i first put foot down it is a bit weak but picks up after 2k revs, smokes on first start up when cold but not sure bout driving normally - don't notice anything
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Try giving it a service and check all vacuum pipes/boost pipes for splits
