Results 1 to 10 of 17
Thread: Hid kit has arrived....
    Full Member axelf's Avatar
    chester le street
    Default Hid kit has arrived....
    Well the kit arrived about 13:45....so built up both sides just to see how they go together.......very easy......now to try on the car.....Removed the air box completely on drivers side and there was enough room to change the bulb no problems, used double sided tape (for holding number plates) to secure the boxes to the inside of the wings out the way.....Opened up battery tray cover and twisted the washer filler neck off the passenger side and again enough room to change the bulb, secured the boxes in the same mannor....Boxed it all back up job done in 1hr 15mins........Cant wait till it gets dark.......pickys up later on the brightness, The kit was 35w 6000k....
    Regular Member bobby-tupper's Avatar
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    top bloke, cant wait for the pics
    Regular Member simon1's Avatar
    Oct 2007
    Leicester
    Vehicle : Vectra elite
    Engine : 1800
    Mileage : 80000
    any pics to show were you mounted them mine ordered today should be here in the morning
    Regular Member decks's Avatar
    Apr 2008
    nothern ireland
    Vehicle : 2.0t btcc
    did you use your old bulb holders or did you get diffrent ones
    chester le street
    As you are looking at the car from the front bonnet open,go behind the headlight, on the drivers side, there is a square shaped hole...Same on the passenger side, i put tape on and secured them in there you can just see the boxes in the pics....hope that helps....
    chester le street
    You get bulb holders in the kit, but i couldnt get them to fit correctly.....so moddified the original 1s.....they will only fit 1 way so i cut out a small section just to get over the wires...
    chester le street
    Well it s dark outside so i went to play.........
    My wife asked me if i had the main beam on....God the differance is unbeliveable......So pleased i got them now...
    What you think??
    Using no flash and no street lighting.....
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Good, innit
    Regular Member r.bailey63's Avatar
    Mar 2007
    Stockton on Tees
    Nice ! Where did you get them from ?
    chester le street
    @ r.bailey...phoned Hids direct....£66 delivered...orded Weds, Delivered and fitted on Thurs.......
  1. It's Arrived!!!
    By Mark The Cabby in forum Insignia car chat
    Last Post: 7th April 2009, 22:09
  2. BSR PPC Arrived
    By vcdti in forum Diesel Engine related
    Last Post: 13th October 2008, 23:16
  3. TV mag arrived
    By shan in forum General Chat
    Last Post: 26th November 2007, 22:33
  4. They've arrived.......
    By spoons in forum Vectra C / Signum Car Chat
    Last Post: 19th November 2007, 18:36
  5. Just arrived!!!!
    By BIG NEIL in forum Introduce yourself.
    Last Post: 4th November 2007, 21:01
