Results 1 to 10 of 19
Thread: vectra vxr brakes
    middlesbrough
    Default vectra vxr brakes
    can anyone tell me if vectra vxr discs and calipers go straight onto a cdti 150 thanks
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Yes but you'll need the caliper carriers too
    Regular Member Jezzy's Avatar
    S.E
    And probably bigger wheels as well, depending on what you have at the moment.
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Although as its an XP you have you'll probably have at least 18's which will be fine
    Regular Member danBoy's Avatar
    Jun 2006
    Northampton
    From what I've seen when I looked back in his posted threads its got 19's on so no issues.
    You'll just need disc, pads, calipers and caliper carriers. The shield at the back of the disc may require cutting as well.
    Are you buying them from a guy on ebay...?
    middlesbrough
    a pal of mine has the full set up hes asking for £400 or fronts for £300 is that a sensible price. Also would i need to change the front flexi thanks
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Bite his hand off mate, the fronts alone are about 700 quid new from courtenays
    And you might want to change the flexi's to braided pipes, its only an extra 50 quid
    780 squid, plus about 500 for the rears...
    Having said that, new pads and discs for the fronts are 400 quid from VX alone, so secondhand buys are only really worth it if you get nearly new discs and pads with them. If you buy a setup for the fronts for (say) 300 quid, but the discs and pads are shot, then you end up spending another 400 to buy new ones and the cost has then risen to almost the same as a brand new setup...
    Regular Member Netstar's Avatar
    Jan 2006
    South Wales
    not sure what that price of £700 is for, but i just ordered a set of front brake disks for my VXR, all be it not standard, but they are 345mm (same as standard) grooved disks and a set of yellow stuff front pads for £418 delivered from Courtenay sport
  1. vectra sri 150 brakes
    By tazdog03 in forum Vectra C / Signum Car Chat
    Last Post: 18th October 2012, 01:00
  2. Vectra Brakes
    By 1.9VCEstateChris in forum Suspension, Wheels & Brakes
    Last Post: 15th June 2012, 22:09
  3. Vectra 2.8T V6 (250) front brakes?
    By the_rocker in forum Handling & Braking
    Last Post: 11th April 2012, 14:12
  4. vectra vxr brakes
    By signumturbo04 in forum Vectra C / Signum Car Chat
    Last Post: 9th June 2010, 16:04
  5. vectra b big brakes
    By TIMMAH in forum General Chat
    Last Post: 31st January 2008, 10:35
