Thread: heating vent removal
    Regular Member purple170503's Avatar
    kent
    Default heating vent removal
    My son was helping me clean the inside of the care, turned away for a split second and looked round to see that one of the slats on the centre heating vents was now missing. Its still there but looks like its come away from the mechanism so when I close the vent there is this little gap at the bottom. I want to try and fix this hopefully if there isnt anything broken inside, can anyone give advice on how to remove the vents? Thanks
    Blantyre
    Open the passenger door and remove the trim that runs along the dash, give a good yank, should start to come away , there are screws under neath that, once you remove the screws the heating vents come out, should allow you to sort it
    kent
    thanks spenny
    kent
    Had a go earlier at removing the trim, is there a knack, all I got was an almost cracking sound and it wouldnt nudge,
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    you gotta start from the passenger side 1st a slight tug should pull the trim away
    Blantyre
    and open your glove box, dont be scared to give it a good pull ( as i say to the mrs )
    Are you VXR Enough
    13 Post(s)
    Quote Originally Posted by spennny View Post
    psml
    Jul 2009
    NEWPORT
    Iv'e got spare slats in the boot of my car so if you want some to fix your's just send me a pm with your details and i will send some over for free !
    Jan 2010
    Middlesbrough
    Ignore
  1. Rear Vent Removal
    By Tam80 in forum Bodywork & Interior
    Last Post: 29th April 2011, 13:53
  2. Air vent removal
    By Jabbekot in forum Bodywork & Interior
    Last Post: 10th November 2010, 11:11
  3. Heating temperature control not working - Full heating permanently
    By jratcliffe3 in forum Electrical & ICE (including SatNav)
    Last Post: 31st January 2010, 23:46
  4. Passenger side air vent removal
    By 726181 in forum Bodywork & Interior
    Last Post: 8th April 2009, 12:21
  5. Air vent removal middle and top of dash.
    By muzzy in forum Vectra C / Signum Car Chat
    Last Post: 1st September 2008, 20:52
