Thread: gear lever surround
    Regular Member old cruiser's Avatar
    slough
    Default gear lever surround
    Guys,what's the safest way of lifting off the gear lever surround (manual box) to get to gear linkage without breaking it!! need to grease the joints in there as the gear lever's getting a bit notchy, also what's the best grease to use without affecting what are probably plastic/nylon joints.
    Cheers Pete
    Blantyre
    Take off the gator, should just pull off, then there are 4 ( i think) torx screws holding it in place, remove them, there is a rather large white pin that needs to be removed , slide this out, then at the bottom its like a ball joint, if you have a long screw driver, " pop " it off, very easy to do mate, i have dome 3 gear stick changes so far, if you need a hand , and fancy a drive , am in Farnborough ;o)
    slough
    Thanks for that mate, are you saying the gator itself just pulls off as it looks like the gator is attached underneath the surround as it were.
    Cheers Pete
    Oct 2009
    Teesside
    Pete, give the gator a good tug and it will pop off, dont be shy as it can be a bit tough, I always take mine off when I clean the car to get rid of all the dust!
    Regular Member carpet's Avatar
    Jul 2006
    TENTERDEN KENT
    The plastic surround is held in place by 4 lugs 2 each side.To remove use the old screwdrive trick each side and the thing normaly comes of ok.
    slough
    Thanks for your help guys will give it a go.
    Cheers Pete
    Blantyre
    Quote Originally Posted by old cruiser View Post
    Cheers Pete
    Its easy mate, I was worried about changing the whole gear stick, turned out to ba a 20 min job start to finish
    slough
    Quote Originally Posted by spennny View Post
    Thanks mate, I often find this that sometimes these jobs look like they are going to be a pain but in the end turn out to be quite easy and straight forward, was just a bit worried I might break the surround, as sometimes I can be a bit ham fisted, as the missus keeps telling me !!
    Cheers Pete
  1. Gear lever,gear selector
    By jodiexii in forum Vectra C / Signum Car Chat
    Last Post: 22nd January 2013, 09:43
  2. Gear lever surround with chorme ...
    By MAF 3.2 V6 GSi in forum Parts for sale
    Last Post: 6th April 2009, 18:30
  3. Gear lever surround
    By bigmac in forum How much is it worth? (THIS SECTION IS NOW CLOSED)
    Last Post: 29th January 2009, 11:17
  4. gun metal gear lever trim plastic surround
    By nph1 in forum Parts for sale
    Last Post: 15th November 2008, 22:50
