Thread: 4th Swirl: Covered in Oil 1.9CDTI 150
    Regular Member barkzz's Avatar
    Default 4th Swirl: Covered in Oil 1.9CDTI 150
    Hey Folks,
    VX replaced my egr a few weeks back after me complaining about:
    "Juddering on startup, with grey smoke emitted from exhaust, combined with poor fuel consumption, and poor perforamnce below 2k"
    However the issue has pretty much returned. Took the cover off tonight to have a look, and theres a definate patch of black oily crap building up around the 4th swirl valve (Far Right). The bar is still attached, but this 4th swirl looks in real bad condition compared to the other 3 which are there.
    I spotted this a few weeks back, but the oily patch wasnt as bad then, but is defiantely worse now.
    Im getting it booked back i again, but this develeopment combined with the smokey/juddery startups would seem to suggest either injector issue or inlet manifold issue would it not?
    Thanks for your help
    Regular Member davieboy1976's Avatar
    hamilton scotland
    Mines was doing exactly the same m8 and the dealer had to replace the egr and the inlet manifold, going gr8 now though
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP NAV
    Engine : 1.9 CDTi 150
    The oily build up is defo the start of the inlet manifold problems mate....
    Quote Originally Posted by davieboy1976 View Post
    Crap i thought it might be.
    I think this is the main reason for the start of the reduced fuel consumption.
    Thank God it's under warranty still.
    I'm a bit peeved as they have done the EGR, but vauxhall being vauxhall they must have purposely left inspecting the inlet out of the equation.
    What's more annoying is the fact that the "laptop says no" when it comes to the manifold, as it generally doesnt produce any fault codes
    Full Member GazVXLINE170's Avatar
    Jun 2007
    Scotland
    Vehicle : Insignia
    Trim : SRI VX-Line Nav
    Engine : 2.0 CDTI [170 PS]
    Year : 2015
    Mileage : 27000
    If the car is in or just out of warranty try vx.....escpecially as they may at least pay half the cost should the car have a healthy service history with them....if you are out of the warranty period.
    As the guys said before this is the start, the flaps can move up and down allowing the greasy/sooty stuff you spray outside of the manifold. The car may drive without limp mode but the performance will take a dip.
    Hope you get it sorted though.
    Gazza4
    Insignia VX-Line Nav CDTI 170.
    Quote Originally Posted by Gazza4 View Post
    Gazza4
    The car is still under VX warranty, so I expect them to cough up in full, as I will refuse to pay a single penny. Obviously a crap design with the older inlets hence the modified version to prevent the same problem.
    Car also has full VX service history, and ill be continuing to service it there so long as I have the vehicle, purely becuase of these reasons.
    That would make sense about the top end of the rod lifting letting the crap through. I take it the 4th swirl valve is essentially sticking compared to the other 3 in that case?
    It's annoying becuase it is a cracking engine, just so sodding fragile
    Regular Member clightowler's Avatar
    Oct 2007
    Leeds
    Trim : SRI hatch
    Engine : z19dth
    Mileage : 110000
    Just taken delivery of mine yeaterday and noticed relatively poor fuel economy (42 MPG on motorway at 70) which around the same as I got on my 1.8petrol this obviously started the alarm bells ringing so after taking the cover off I have noticed exactly same as described, 1,2,3 all ok but 4 with what looks like lithium or graphite grease seeping from around sides (see pics). I assume this is the start of the dreaded inlet manf failure. car is a 56 plate with 32.5K on the clock. Images are in order cylinder 1, cylinders 2 + 3 and the last two show cylinder 4 with different lighting.
  1. repairing 1.9cdti swirl valves.
    By bigjoe8707 in forum Vectra C / Signum Car Chat
    Last Post: 3rd July 2010, 09:55
  2. vectra c 1.9cdti swirl valves
    Last Post: 25th June 2010, 20:30
  3. swirl valve rod..problem on my 56 reg 1.9cdti or not??
    By marky2027 in forum Engine & Drivetrain
    Last Post: 17th October 2009, 20:22
  4. network q warranty covered/not covered
    By johnturbo in forum Vectra C / Signum Car Chat
    Last Post: 21st June 2009, 15:34
  5. swirl and boost sensor 1.9cdti 150
    By mark230678 in forum Engine & Drivetrain
    Last Post: 25th May 2009, 20:09
vauxhall.signum 1.9cdti oil around.swirl valve
