Thread: Keeps cutting out
    Regular Member David's Avatar
    peterborough
    Angry Keeps cutting out
    car is 3 days out of warranty, has started just cutting out, all power goes off then when you turn the key everything comes back on, usually does it after or during a corner which is no fun as the power steering goes off, whats wrong, somebody has suggested it is the crank shaft sensor
    Regular Member The Doc's Avatar
    'Norf Yorks.
    Quite possible, though a air leak could also do this.
    peterborough
    Default cuts Out
    where from, the back rear tyre looks a bit flat
    John means an induction air leak, a loose clip or split hose on the intake system..
    if it's mainly cornering it could also be a faulty ' crash' sensor telling the car it's had a shunt, even though it hasn't..
    it's off to the dealer for you mate..
  1. 1.9 150 cutting out
    By japkadett in forum Electrical & ICE (including SatNav)
    Last Post: 17th May 2012, 21:26
  2. Cutting out
    By Chuddy in forum Engine & Drivetrain
    Last Post: 23rd January 2010, 22:37
  3. my car kept cutting out??
    By Curly7 in forum Vectra C / Signum Troubleshooting
    Last Post: 10th January 2009, 21:23
  4. 2.2 dti cutting out in 4th and 5th
    By j brown in forum Engine & Drivetrain
    Last Post: 12th May 2008, 20:34
  5. Cutting out!
    By Mike 3.2 GSI in forum Vectra C / Signum Car Chat
    Last Post: 16th August 2005, 13:04
