Thread: Main Beam Adjustment
    Aug 2007
    Bath
    Default Main Beam Adjustment
    I have searched the threads but cannot seem to find an answer to this question:
    How do you adjust the Main Beam lights?
    I have seen items on adjusting the dipped lights but not the main (high) beam.
    The ones on my 04 Signum throw the light too far to the left. On dark country lanes that is fine if you are going round a left hand bend but useless on a right hander.
    Any ideas?
    BTW - Put HIDs in my dipped and they are 1000% better than the old halogens. Well worth the money!!
    Aug 2007
    Bath
    Sorry - probably put this in the wrong section
    There should be no need to adjust the main beam
    If they are indeed out of alignment then that suggests the headlamp assembly needs adjusting
    North Wales / Leeds / South France
    you cannot adjust the main beam on its own, as it is adjusted when you set up the dip beam. follow the how 2 for setting up the dip beam and all will be well.
    Aug 2007
    Bath
    Adjusting the dipped beam only alters the angle of the 'bulls-eye' lens (dipped).
    It does not adjust the headlight unit itself and so has no effcct on the main beam alignment.
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    +1 on that you can't adjust the main beam separately.
    But you could do what I did - the main beam on my 2002 GSi (factory fit Xenons) was way too high, so I tipped both complete headlamp units down by wedging bits of plastic in various places. The main beam came down to something much more acceptable and then re-adjusted the dipped Xenons so that they were back at the right height. I guess I may have been lucky in that I had just enought dipped beam adjustment left to achieve this.
    This may work if your main beam is too low as well by shimming the units the other way.
    HTH
    WGAF#5
    Quote Originally Posted by hefilump View Post
    yup
    moved - no worries
  1. main beam question
    By patch22 in forum Electrical & ICE (including SatNav)
    Last Post: 20th October 2012, 20:22
  2. Main Beam issue
    By Cruize in forum Electrical & ICE (including SatNav)
    Last Post: 4th December 2011, 16:50
  3. main beam adjustment
    By chewy71 in forum Electrical & ICE (including SatNav)
    Last Post: 12th October 2011, 16:09
  4. Are the h/l and main beam bulbs the same ?
    By simac in forum Vectra C / Signum Car Chat
    Last Post: 19th December 2006, 22:13
vectra c headlamp adjustment
vauxhall vectra high beam adjust
vectra beam alligment
vectra c 2002 headlamp adjustment
vectra c headlight beam adjustment
how to adjust vectra c headlights www.vectra-c.com
vectra c headlight adjustment
beam adjuster location vaxhall vectra
how to adjust headlights on vauxhall vectra
zafira b 2011 main beam adjustment
vectra b headlights adjusting
vectra c headlight alignment
vectra c gsi high bea
vectra c headlight main beam
