Results 1 to 10 of 19
Thread: Is my Veccy using too much oil?
    Regular Member gsi.vxr's Avatar
    Hertfordshire
    Default Is my Veccy using too much oil?
    I've got a 2003 3.2 GSi. I change the oil every 8k-10k miles but after about 5k miles the low oil warning comes on. From then on it uses around half a litre of oil every couple of months until I change it again. And so on again! The oil I use is the proper GM Longlife 5w30 Fully Synthetic. Is this normal for it to use this amount?
    Cheers guys & girls
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    How is it driven? Hard or gently? 1/2 litre over how many miles?
    Does it use or lose the oil?
    Hertfordshire
    I don't drive it hard, just brisk. After about 5k miles the warning comes on, then every 1k-1.5k roughly after that until it gets changed. It's not loosing any, 100% on that.
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    It's probably within the oil consumption specification in the manual, BUT IMO it is excessive. Mine doesn't usually use any between 20K mile services (1.8 Petrol).
    Oil consumption is affected by engine type, service regime, duty cycle, oil quality / type etc.
    Other GSi owners may have similar consumptions figures.
    Hertfordshire
    Quote Originally Posted by Ste View Post
    Any GSi owners finding this?
    Thanks by the way Ste!
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Ive never had to top up any of my past cars between servicing, all except the vec-c use to have cheep morrisons oil as well.
    West
    Vx will say theres no problem if your using no more than 1litre in a 1000 miles
    How often and at what time (cold, warm, or hot engine) are you checking the oil level?
    At what level does the warning light come on?
    When you need to topup how much does it take and what level do you refill it to?
    Typical use should be about minimum to maximum once every 10K miles
    However as engine gets older this can increase
    I found this on my previous X20XEV, up to 60K miles I never had to top it up, it was just getting to the minimum in time for the service
    However from then on I had to top it up half way through services
    The cylinder head was then reskimmed at 90K miles and the problem went away
    Regular Member v6vc's Avatar
    Jul 2009
    Planet Earth
    Vehicle : Vectra & Signum
    Trim : GSi & Design
    Engine : 3.2 V6 & 2.8 V6 T
    Year : 02/07
    I've done about 4k in my GSi now and not had to top it up once (hope the sensor is working!). Not sure what grade oil is in it at the moment but is soon to be on 5-30W fully synth so we'll see. Its only done 44k miles so not really expecting much oil consumption.
    Worcs/Staffs/Westmids (ish)
    It could be poor quality oil that's vaporising too easily and being fed back from the crank case into the inlet manifold (as mentioned in the oil catch tank thread).
    Failing that maybe try a higher viscosity oil? it's could be seeping up past a piston ring (which wear with age) and burning off. Take out the plugs and see if one looks a bit gunky.
    You do need to think about increasing the viscosity as you clock up those miles on any car.
  1. Drosser Veccy B old hand Veccy C virgin
    By drosser in forum Introduce yourself.
    Last Post: 27th November 2012, 06:42
  2. Thermostat from a 1999-02 veccy onto a 2003-05 veccy?
    By Drazek in forum Engine & Drivetrain
    Last Post: 9th January 2011, 22:21
  3. Veccy may have to go
    By bigknill in forum Vectra C / Signum Car Chat
    Last Post: 16th April 2010, 22:51
  4. Veccy C to replace Veccy B?
    By gtr1000 in forum Vectra C / Signum Car Chat
    Last Post: 19th June 2008, 08:49
  5. V6 Veccy-B to Oil fired Veccy-C
    By Alpha10 in forum Introduce yourself.
    Last Post: 8th February 2006, 09:22
vectra c using too much oil
opel gsi consumes too much oil
