Thread: Rear Interior Lights in Estate
    Nov 2009
    Derby
    Default Rear Interior Lights in Estate
    Hi all,
    I have a 58 plate design estate. I need to put some decent interior lights in the back. Can I just wire them across where the existing ones are? Also is there any way to increase the length of time they stay on. They keep going off whilst I'm wotking in the back of the car. Alternatively can I pick up a Battery feed to wire up a light to the rear power socket.
    Thanks for any help
    Pete
    Sep 2009
    Swindon
    I think there is a how2 in the how 2 section with details on fitting a rear interior light.
    Frenchman
    Nov 2009
    Derby
    Thanks for that Frenchman, but the fusebox in the HOW 2 must be a slaoon or hatch as it's different to mine. Any body else got any ideas how to pick up a battery feed in an estate luggage comp?
    May 2007
    West Yorkshire
    Tap off the power in the boot (fused down) and place an inline switch in the side panel, that way they wont go off.
    Nov 2009
    Derby
    Cheers Sshooie,
    That's what I thought, but was asking if anyone knows where's the best place to pick up a permanent battery feed on the rear fuseboard?
    Regular Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    There will be a very large 40 amp fuse in the top right hand corner of the fusebox in the boot area.
    You can put a male spade connector in one of the fuse point slots above or below this, and then run your permanent feed into your lighting...remember to use an inline fuse...
    There is definately a thread here somewhere for fitting a permanent live cigar socket in the rear load area of an estate...bear with me and I shall seek it out!!
    here it is..
    http://www.vectra-c.com/forum/showthread.php?t=11536
  1. rear fog lights on vec Estate
    By tonyt in forum Vectra C / Signum Car Chat
    Last Post: 9th December 2008, 08:58
  2. Rear Interior Lights Fitted in Estate.
    By Vectra-Dog in forum Styling
    Last Post: 4th May 2008, 07:46
  3. Rear Interior Light in an 06 + Facelift Estate
    By logi6260 in forum Vectra C / Signum Car Chat
    Last Post: 28th March 2008, 20:56
  4. rear interior light estate
    By learoy69 in forum Vectra C / Signum Car Chat
    Last Post: 1st March 2008, 16:42
  5. rear interior light estate
    By learoy69 in forum General Chat
    Last Post: 19th February 2008, 14:11
