Thread: I have ballzed up....doh! (HELP!!!)
    Regular Member DTGB's Avatar
    Basingstoke, Hampshire
    Unhappy I have ballzed up....doh! (HELP!!!)
    I am really concerned now as I have just taken my Z22SE veccy for a drive to see if my efforts had made a difference....its made the 'pick up' better i think. (i cleaned my throttle body & put iy back together as per one of the how 2's)
    The worry i have now is that when i dip the clutch to change gear, the revs on the rev counter dont appear to drop as quickly as they should....they seem to be hanging a bit....now i'm worried i've ballzed something up big style.....HELP, I AM NOW IN YOUR HANDS!!
    Wales, UK
    Dont think it sounds that bad mate.
    Long shot but are the little breather pipe things on correctly ?
    Regular Member v6vc's Avatar
    Jul 2009
    Planet Earth
    Vehicle : Vectra & Signum
    Trim : GSi & Design
    Engine : 3.2 V6 & 2.8 V6 T
    Year : 02/07
    I haven't seen the 'how to' that you mention but, did you clean the idle valve? If so, did you oil it back up with some 3 in 1 oil or similar?
    I used to have an idle revs problem on my old Astra which was always the idle valve. Either the gasket wasn't doing it's job or it just needed a clean and oil up.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 110000
    Quote Originally Posted by mark_647 View Post
    No breathers on 2.2 TB mate.
    Quote Originally Posted by V6VC View Post
    No idle valve either, the TB butterfly control's idle on the 2.2
    Quote Originally Posted by DTGB View Post
    Same as I said in your other thread mate, as the idle is controlled by the butterfly, now that you have cleaned it more air is getting through. The only thing it might be is if you unbolted it and didnt bolt it back on properly.
    Cheers everyone.....I will have a good look at it in the daylight tomorrow
    Will unbolt it & try again Rushy.....of course, it may be that because te TB is spotless, its running exactly how it should be?!!
    Vehicle : SRi
    Mileage : 110000
    Just pop a smear of oil on the rubber gasket when you put it back on.
    Will do.....thanks
    Now I am thinking about it, it didn't seem to screw back on quite as sweet as I thought it might. I will give it a bit more care tomorrow
    Regular Member 900ss's Avatar
    May 2008
    Bucks
    Sounds like as air leak
    Wales, UK
    oops lol - Ignore me.....
    Jul 2009
    Planet Earth
    Trim : GSi & Design
    Year : 02/07
    And ignore me too ....
