Results 1 to 10 of 15
Thread: 2.0DTI limp mode.. AGAIN!
    Jun 2009
    Belgium
    Eek 2.0DTI limp mode.. AGAIN!
    Hello,
    I will try to make descent posts, but it won't be perfect English I guess.. So please don't shoot me for that
    About a half year ago my car became a frustrating machine(like for a lot of people..) When I was doing about 120km/h on the highway. PLING!! The famous spanner light popped on the dash and the car felt like a Flinstone vechile, No More Power .
    So, I cruised over the Internet and found alot of info. (EGR, Turbo, Vacuum pipes etc.) After buying a code reader (OP-COM) I popped the hood and found a vacuum pipe with a split (Me was very happy ). I fixed the pipe and cleaned out the EGR valve. (Did this about 3 months ago).
    Yesterday.. When doing 120km/h on the highway.. Guess what? Limp mode. I hate this mode.. It has a top speed of 120km/h and I can't accelerate deccently. The only thing I can do is pull over stop and start the engine and then the spanner and limp mode is gone (for a few minuts)
    Now today I plugged in the OP-COM interface and had the following error: P0400 - Exhaust Gas Recirculation Valve Feedback Signal Malfunction
    (F8) - Not present
    Who can help me with this very annoying error?
    Thanks in advance.
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Hi m8 i .am assuming that you have a 2.0 0r 2.2 dti lump then the po400 fault is refering to the egr valve , its probably the valve itself that is sticking , all you can do is remove the egr give it a good clean out with carburrettor cleaner and make sure the valve can operate , also why your there you might as well clean the boost sensor and its housing as well .
    I do this every six months anyway as a a matter of course
    and still loving it
    Jun 2009
    Belgium
    I will try that.. Where exactly can I find the boost sensor?
    I'll post a pics
    http://www.uploadarchief.net/files/d...eelding191.jpg
    The questionmark is the Vacuum pomp. In the upper left corner of the rectangle is the boost sensor or is this the mass airflow sensor?
    Here is an overall picture, the things in the box I know
    http://www.uploadarchief.net/files/d...eelding187.jpg
    East Midlands
    Dutch..the boost sensor is the blue coloured plug to the top left of the box in your pic.
    Incidently.?Have you checked the boost /intercooler hose for splits ,looks as if its had some hammer,and its a common fault on this engine.
    Follow my" How To" clean the egr even if it is'nt the main cause of your problem.
    New Member JouniBoy's Avatar
    Jan 2010
    Finland/Turku
    I have same problem,I buy new EGR valve and now it is working well.My -99 2.0 DTI vectra has over 500 000 kilometrs on tacho.EGR is leaking so there is not enough vacuum on the system -> car goes to the limp mode.
    Regular Member jonnynufc's Avatar
    Belfast
    my car is the exact same. as soon as i hit 70mph it dies, my spanner light is constantly on though, ive replaced egr valve, vac pipes and it needed a new turbo, still got the same problem though, i also have to stop and restart the car then its fine until you hit 70mph again
    Jan 2010
    Finland/Turku
    Quote Originally Posted by jonnynufc View Post
    Is your vacuum pump in order?Maybe better test it,it is easy.Mine pump produced 95 KPA.
    http://www.youtube.com/watch?v=iPwkmN_pPMA
    And how about dirty intake manifold?Also common problem in DTI:s.
    http://www.opelclubfinland.fi/forum/...?f=19&t=147602
    uk
    Did you get it fixed?
    Jun 2009
    Belgium
    Yes I got it fixed !
    It is a way that is also recommended by the Autodata software if you have a code P0400 stored and your car is going in limp mode. It should work on following car models with an 2.0 or 2.2DTi engine with a PSG-16 Motor control unit.
    Astra-G 2003-2004
    Zafira-A 2003-2004
    Vectra-C 2002-2004
    Signum 2002-2004
    The problem is caused by a broken position sensor in the EGR-valve. Its been suggested to cut the cable 4 (the Gray/Black one) from the EGR connector wich is connected to pin 16 of the motor control connector. When cut, you must isolate both ends.
    I can only say, this helped me a lot. If you have the same problem, I can only suggest you try this. It is an ultra cheap solution. However, I also suggest that once a year or 2 years, you take the EGR valve out for a clean
    I hope this helps.
    Greetings.
    Jul 2009
    Leicester
    Has anyone else tried this?
  1. 2.0Dti went Bang then into Limp Mode
    By TonyP2020 in forum Engine & Drivetrain
    Last Post: 25th April 2011, 23:14
  2. 2.0DTI Engine Fault - Limp Home Mode Over 3000 RPM
    By coxstevuk1973 in forum Engine & Drivetrain
    Last Post: 4th March 2011, 17:03
  3. limp mode again and again and again stupid 2.0dti
    By barrymanalow87 in forum Diesel Engine related
    Last Post: 8th May 2010, 23:57
  4. Just got back..After limp mode saga..03 2.0dti
    By macdad in forum Vectra C / Signum Car Chat
    Last Post: 11th July 2009, 15:04
  5. limp mode+sort of usual problem 2.0dti
    By bobssignum in forum Engine & Drivetrain
    Last Post: 8th August 2008, 19:04
vectra c egr
astra 2.0 dti engine
vectra 2.0 dti
vectra 2.0 dti electronic fault limp mode
2002 2.2 vectra c spanner light came on now in limp mode
vauxhall zafira2.0dti vacuum pipes
czujnik ciśnienia doładowania vectra c 2.2 dti
zafira dti limp mode
vectra 2.0 16v diesel limp home mode
opel vectra 2.0 dti vacuum pump
vectra c 2.0 dti
motor vectra c 2.0 dti
P0400 vectra 2.0 dti
p0400 opel zafira 2.0 dti
dti air intake limp mode
opel vectra b hűtőrendszer
vauxhall vectra 2.0dti engine model numbers
mk 4 astra 2.0 dti agr valve fault
zafira 2002 egr
vauxhall vectra turbo diesel limp mode
opel 2.2 dti vacuum leak
Vectra C manifold sensor
vauxhall vectra 2.0 dti common faults
common vacuum fault with the 2.0 dti
vauxhall vectra 2.0 dti limp mode
