Results 1 to 10 of 21
Thread: CDTi 150 Whining noise
    Cambridgeshire
    Default CDTi 150 Whining noise
    My vec is making a whining noise on acceleration. It's quite high pitched and starts at about 1.5k revs and gets a little louder when I go faster. The noise is coming from the engine bay. I thought it was just the turbo spooling, however my mate has a 150 as well and his doesn't make this noise.
    There's no extra smoke coming from the exhaust, other than normal.
    I've checked the power steering (vec b's PS can whine) and it's not that. I've also checked that there isn't a woman in the engine bay
    The car's just had a major service, with a new cambelt,water pump, DM flywheel and clutch plates.
    Does anybody know what could be causing this? My main worry is that the turbo is on the way out!
    Cheers for any help.
    Dave
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Could be from the Alternator / Aux Belt area.
    Does it do it all the time, or when cold / warm etc..?
    Cambridgeshire
    It does it all the time mate, I'll check the alternator and belts, thanks
    Jun 2009
    Norwich
    Simota induction kit?? mine wines and whistles like mad!!!
    Oct 2009
    Teesside
    Mine does it when cold, sounds like a police car on a morning lol, think its the Alternator bearings as Dan said...used to have the same things on the calibras (which was a sure sign the alternator was on its way out )
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Is it engine or vehicle speed related? Underload, steady state, on over run, in neutral etc.
    Bit more info required methinks.
    Cambridgeshire
    Thanks for the replys. A bit more info; It seems to be engine speed related, i.e. it will make the noise while standing still and in neutral, goes up in pitch when you accelerate and drops when you take you're foot off. However, it also does it while driving. Cold or warm doesn't seem to make any difference either. The turbo seems fine, kicking in around 2k revs and pulls as it should.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    If it is happening 1500rpm and hits its noisiest between 2,000-3,000rpm, then its possibly the turbo on its way.
    Hope its just a slipping belt or alternator m8.
    Gazza4
    Jul 2009
    ireland
    any info on this as i am having the same problem same symptoms?? with my 1.9 cdti 120
    Bristol
    Vehicle : CDTI 150
    If the cam belt is over tensioned then you can get a whine from that.
    Did the whine occur after the cambelt change?
    If so take it back
  1. whining noise
    By Swedge in forum Engine & Drivetrain
    Last Post: 21st November 2012, 23:23
  2. whining noise on my CDTI 150 SRI
    By karlbutler in forum Vectra C / Signum Troubleshooting
    Last Post: 15th October 2010, 16:48
  3. whining noise (HELP)!!!!
    By wilsons 1.8sxi in forum Engine & Drivetrain
    Last Post: 20th March 2009, 09:03
  4. Whining Noise
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 11th August 2008, 09:08
  5. Whining Noise
    By v6boy in forum Engine & Drivetrain
    Last Post: 13th May 2007, 01:13
vectra c whining noise when accelerating
https:www.vectra-c.comforumshowthread.php95559-CDTi-150-Whining-noise
vectra c alternator noise
vectra c 1.9 cdti alternator bearing problems
vectra c z19dt humming noise from timing
high pitch whine mg zt cdti
vectra whirring noise turbo
vectra 1.9 cdti alternator whine
vectra c 1.9 cdti alternator whine
mgzt deisel whineing noise
vectra 150 whirring
vauxhall vectra c 1.9 cdti 120 turbo noise
zafira 1.9 humming noise
vectra noise at 2500 rpm
vectra noise at 1500 to 2500 rpm
vectra making whining noise
vectra c grating noise at 2000 rpm in neutral
insignia whining noise when revving
2004 vectra whining
vauxhall ventral 1.9 150 whining
vauxhall vectra sri alternator squeal
vauxhall insignia engine whining sound
vectra c turbo noise
vauxhall insignia engine makes a whirring noise
vaxhull vectra 1.9 cdti squeeking noise coming from timing belt
