Results 1 to 10 of 21
Thread: crankshaft pulley
    Nov 2009
    southampton
    Unhappy crankshaft pulley
    hi i'm new to the site and would like to know if anyone has had a crankshaft pulley brake on there car i own a signum 2.2 DTi and on friday the 13th it broke away but the engine still ran. so all i'm asking is it a simple job to fix or anyone know how much it might cost to fix?
    just what i need comin up to xmas lol
    Regular Member danBoy's Avatar
    Jun 2006
    Northampton
    Its a common problem.
    I work for LMF Vauxhall and I can supply a brand new pully for £59.95 plus £8.50 shipping.
    I've no idea what sort of cost fitting will be though.
    Nottinghamshire
    Quote Originally Posted by djsoundman View Post
    Quite a few of us have had this - including me. You would be well advised to get a genuine Vauxhall pulley - cheaper aftermarket one are available but can be too heavy and/or not balanced properly and cause vibration.
    You'll also need a new pulley bolt. Cost of genuine parts is around £170 but worth it for peace of mind and lack of problems in my opinion. The old bolt will be in extremely tight - it took a 1" impact driver usually used on lorries to get mine out! Total cost including labour for me was about £230 from an independent Vauxhall specialist.
    Do a bit of seaching on here to find out other people's experiences, recommendations, and problems. Well worth a few minutes of your time.
    PS - my comments are not a reflection on the part LMF sell because I didn't get mine from there and I don't know who makes the ones they supply. If it's a genuine part for that price then it's a great deal!
    Nov 2009
    southampton
    thanks guys i'll keep you all informed as to which route i take lol thanks for the info james and danboy
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Why do you need a new bolt?
    Nottinghamshire
    Quote Originally Posted by Ste View Post
    Because it's large, tightened to a high torque, been in there for years, and takes an impact driver to get out. I don't know how you'd get the remains out of the crankshaft if a weakened re-used bolt sheared off, or what damange the new pulley could cause if it broke free at high revs.
    Also, the bolts only cost about £10 and I'd rather pay that and have peace of mind - and both TIS and Haynes say to fit a new one.
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    I didn't fit a new bolt on my 1.8 when i have replaced the timing belt (twice) - yes it is tight, but didn't need an impact driver to remove it.
    Nottinghamshire
    I haven't seen the bolt for the 1.8 petrol but as the engines are totally different, then I guess that the bolts may be quite a bit different too. I notice that the torque for the bolt on the 1.8 petrol is quite a bit lower than the one for the DTI's for a start, but it is actually recommended to change the bolt on the 1.8.
    I have stated the reasons above - including the fact that the manufacturer says to replace the bolt. That's good enough for me - especially for the sake of £10 and because we're starting to stray from the main topic a bit - crankhaft pulley replacement on DTi engines.
    Bristol
    Vehicle : CDTI 150
    There is a how 2 on this site to change one of these.
    Nov 2009
    southampton
    i've just mannaged to get to the pulley from under the car and i took out the loose bit its the rubber that has gone so looks like all i'll need is a new pulley wheel thank god
  1. Crankshaft pulley. Vec c and b ??
    By Lordish in forum Vectra C / Signum Car Chat
    Last Post: 13th April 2012, 18:43
  2. Weight of crankshaft pulley
    By tosh23 in forum Vectra C / Signum Car Chat
    Last Post: 1st June 2011, 08:26
  3. Crankshaft Pulley
    By 123ashleyp in forum Engine & Drivetrain
    Last Post: 5th March 2010, 12:37
  4. Crankshaft Pulley again!
    By ANDY H137 in forum Vectra C / Signum Car Chat
    Last Post: 31st May 2009, 14:34
  5. Yet Another Crankshaft Pulley!
    Last Post: 13th January 2008, 00:27
Put crank pully on vectra c
