Thread: recommend a cam sprocket removal tool?
    Sep 2009
    Swindon
    Default recommend a cam sprocket removal tool?
    Hi guys,
    Looking for a recommendation for a tool I can use to hold the cam sprocket still while I undo the bolt, I think Vauxhall use a tool called KM956-1. Need something that will definitely work with a 1.9cdti 8 valve and not to expensive
    Can't believe they put half of the water pump behind the cam shaft pully, but there you go!
    Frenchman
    Regular Member r.bailey63's Avatar
    Mar 2007
    Stockton on Tees
    Sep 2009
    Swindon
    Hi thanks for the link, it is the right price anyone used this tool on the 1.9 8 valve?
    Frenchman
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    If it looks anything like the 1.8
    then it wouldn't be too difficult to fit something to the sprocket to hold whilst removing centre bolt.
    Sep 2009
    Swindon
    Unfortunately the sprockets are spaced apart so it's a hand held tool that I need.
    Frenchman
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Yes, (ignore the red circles, they're just showing the timing marks) are the sprockets solid or have holes in, like the pic) on yours?
    Mar 2007
    Stockton on Tees
    Quote Originally Posted by Ste View Post
    If the sprockets are like these then it will work fine, i bought one to do the head on a k16 and the sprockets were very similar.
    Sep 2009
    Swindon
    The sprocket is the same as pic no 1 in post 9 in this thread. http://www.vectra-c.com/forum/showth...270#post668270
    I have spoken to my mate who is a fiat expert, and he reckons it's good practice to remove the cam cover and mark it up before I remove the bolt, more things to take of the car lol.
    Frenchman
    Mar 2007
    Stockton on Tees
    Quote Originally Posted by frenchman View Post
    Should work fine with that type of sprocket.
    Sep 2009
    Swindon
    Cheers guys
  1. inner tie rob removal tool
    By chris1804 in forum Suspension, Wheels & Brakes
    Last Post: 8th September 2012, 18:59
  2. Radio removal tool
    By greeningr in forum Electrical & ICE (including SatNav)
    Last Post: 25th July 2012, 05:26
  3. Recommend Me A Tool Kit
    By spennny in forum The 'Off Topic' room
    Last Post: 20th April 2011, 08:15
  4. What Tool for Flywheel bolt removal?
    By stupot555 in forum Engine & Drivetrain
    Last Post: 10th February 2011, 09:30
  5. recommend me a tool set
    By Morephun in forum General Chat
    Last Post: 5th March 2009, 19:41
holden astra head gasket timing marks
who to set timing of opel astra 1.8 16
