Results 1 to 3 of 3
Thread: Oil Level Warning Light
    Regular Member Gogs67's Avatar
    Jan 2006
    Dunfermline
    Default Oil Level Warning Light
    Hi to all
    I have a 2006 '06 facelift SRI 1.8VVT. During the past week, the yellow oil level warning light has come on a few times whilst driving. On each occasion, I've stopped the car and checked the oil level, however every time the oil level is up to the maximum on the dipstick
    No water in the oil, and no oil leaks evident anywhere. On restarting the engine straight after checking the oil, the light is still on; however if the car is left overnight the light is off.
    Oil & filter were last changed 6 weeks ago just after I bought the car, using genuine synthetic Vx oil & filter; also flushed beforehand. Previous oil had been in for 20k and was fairly manky.
    Could this be a faulty sensor? If so is it a straightforward replacement? Where is the sensor located?
    Any advice/suggestions gratefully received.
    Many thanks in advance
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    Hi Gogs
    it's in the sump,if yours is the Z18XE or Z18 XEL it's just a matter of draining sump removing wiring harness,4 bolt's fit new sender to mounting plate and refitting(fit a new gasket also)
    Regular Member benny's Avatar
    Feb 2006
    dudley
    could be a short dip stick they did have a few problems with the odd engine haveing the wrong one there is a feild remedy on the tis system about it if some one wants to look it up for you
  1. Oil Level warning light
    By Bren G in forum Electrical & ICE (including SatNav)
    Last Post: 9th September 2012, 21:55
  2. Fuel level warning light......
    By Nik in forum Electrical & ICE (including SatNav)
    Last Post: 20th July 2011, 00:44
  3. Intermitent Oil Level Warning Light - 2.8 V6
    By luke4487 in forum Engine & Drivetrain
    Last Post: 22nd May 2011, 15:06
  4. Coolant level warning light
    By phils in forum Vectra C / Signum Car Chat
    Last Post: 21st May 2011, 21:22
  5. Oil Level Warning Light issue
    By Blagmeister in forum Engine & Drivetrain
    Last Post: 14th March 2010, 18:23
