Thread: Still problmes wiht EML light and cutting out.
    Regular Member affirmation's Avatar
    May 2008
    Pembs
    Default Still problmes wiht EML light and cutting out.
    2.2 petrol LS - z22se
    Ive changed the EGR, de-restricted the airbox and given the throttle body a thorough cleaning!! I'm thinking I've doen everything I can now so looks like a trip to the stealers to work out whats going wrong. The engine rough idles at around 800 rpm!! And cuts out whilst driving - not restarting for about 30 seconds!
    scotland
    air flow metre???????
    EVERYWHERE
    HP fuel pump ?
    May 2008
    Pembs
    Are those things I can check/clean easy enough?
    EVERYWHERE
    No, not really.
    I'm surprised that you haven't got some codes that want reading ?
    It's best to get the codes read before you go any further. But the fuel pumps are a bit of a problem on that engine, apparently.
    May 2008
    Pembs
    Went to the stealers today - they say it has come back with a fault code that means the ECU needs reprogramming or replacing!!!!
    They want it back on friday to have longer with it to see if it can be reprogrammed or if it will need replacing!! does this sound right! the guy estimated £5-600 for ecu replacement!!
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Quote Originally Posted by diesel dog View Post
    HP fuel pump ?
    Not on the Z22SE
    Block the EGR mate. The 2.2 petrol doesn't need one and the ECU won't pick up a fault if you block it
    May 2008
    Pembs
    I replaced the EGR without result - as mentioned teh stealer reckons I'll be looking at a new ecu!
    Regular Member slipperysam1984's Avatar
    Apr 2009
    Bournemouth
    have you got the codes vx read?
    May 2008
    Pembs
    Yeah it was the stealers who read them - they just said it came up with a code that means the ecu either needs reprogramming or replacing!!
  1. Interior Light - Cost cutting again??
    By puppet in forum Bodywork & Interior
    Last Post: 17th April 2012, 20:28
  2. Engine cutting out!! Exhaust emissions warning light! Help!
    By jde1 in forum Vectra C / Signum Troubleshooting
    Last Post: 3rd August 2009, 23:39
  3. Replies: 3
    Last Post: 28th April 2009, 19:49
  4. 2.2 dti Cutting out
    By NBR in forum Electrical & ICE (including SatNav)
    Last Post: 15th April 2008, 23:49
  5. Key Cutting
    By LAV6Y in forum Vectra C / Signum Car Chat
    Last Post: 24th February 2008, 22:32
