Thread: Original VX Front Brake Pads - Arrow Pointing Up or Down?
    Wolverhampton
    Default Original VX Front Brake Pads - Arrow Pointing Up or Down?
    I've changed the front brake pads on my Vectra a couple of times using the aftermarket patterns but this time I was lucky enough to find some of the original non-aftermarket pattern VX pads at a very good price. These are the ones the dealers knock out at £65 a throw so I was well pleased.
    Anyway, went to fit them today and realised that the inboard pads are actually 'handed' ie they are unique to the LH and RH caliper. See the pic below...
    As you can see there is an arrow on the back and if you look more closely there is a half moon shaped cutout in the shim material which corresponds to the curvature of the caliper piston. The arrow either ponts up or down depending which side of the car you fit each pad to.
    My reaction was that the arrow was meant to represent the disk rotation and so it should point down but in in the end I put the old ones back on and decided to post this instead of guessing. One thing I don't want to end up with is squeeling brakes having found some of the top spec pads.
    Can anyone out there help?
    Plymouth
    ....calling glenboy !!!
    Regular Member benny's Avatar
    Feb 2006
    dudley
    arrow in the direction of disc travel ...............................
    Wolverhampton
    Thanks Benny, I thought that must be it.
    Plymouth
    Will they fit either side?? also.. the right hand side one looks like the passenger side front as it looks in the pic thats th eone for the sensor to go on.
    Wolverhampton
    Yes they would actually fit either side. They're identical apart from the integral shim on the back. They also both have the sensor slot! Anyway I think Benny is right, his answer makes sense.
  1. Front Brake Pads
    By Tank988 in forum Vectra C / Signum Troubleshooting
    Last Post: 19th January 2012, 19:05
  2. Vec B front brake pads 1.8, will they fit the Vec C?
    By Caveman_nige in forum Suspension, Wheels & Brakes
    Last Post: 23rd September 2011, 22:14
  3. front brake pads
    By rick1965 in forum Vectra C / Signum Car Chat
    Last Post: 16th September 2009, 12:37
  4. original police spec brake pads 93183729
    By benny in forum Parts for sale
    Last Post: 13th July 2008, 08:33
  5. Front brake pads
    By Marc 100 in forum Vectra C / Signum Car Chat
    Last Post: 14th August 2006, 23:02
