Results 1 to 10 of 13
Thread: Clunking doing my head in!
    May 2008
    Wrexham
    Default Clunking doing my head in!
    Got a cluncking noise coming from front of car, it makes a rattling sound when going over bumpy ground, also when i brake i get a clunk noise.
    my mechanic checked it over and also a mate who is head mechanic in vauxhall, had drop links changed but still same.....checked bush on end of wishbone but thats fine......there is a little play in steering rack but dont know if it would rattle or make cluncking noise. had all under car checked and used iron bar to check for play in anything but nothing visible.
    my mechanic suggested could be suspension bushes, but need to drop subframe to get to them which is a big job, vauxhall mechanic said he had never heard of these going before.
    you guys goy any suggestions
    Wolverhampton
    Have you done your brake pads recently? Might sound daft but cheaper aftermarket pads can rattle quite badly in the caliper.
    I would have said almost certainly drop-links but obviously you've eliminated that one!
    Regular Member barkzz's Avatar
    Sounds like the spring bouncing in its seat to me mate.
    My older 1.8 did it all the time, then there was a sound of metal releaseing itself: SPring had snapped away
    May 2008
    Wrexham
    Quote Originally Posted by barkzz View Post
    have checked the springs and had the upgraded housings futted to
    Quote Originally Posted by liphook View Post
    Hmmm, ARB's or loose radiator mounts?
    Seems a bit odd to say the least
    May 2008
    Wrexham
    what are ARB's?
    it a weird problem, the rattle and clunk can be felt around your feet in the passenger footwell, but as said there is nothing loose round there
    Regular Member Keithy's Avatar
    Jan 2008
    Dundee
    radiator mounts probably. i have play in my steering rack but i only notice it when turning full lock on a cobbled street
    Regular Member Danialj32's Avatar
    Sep 2009
    Warrington
    what are ARB's?
    Yep, want to know this myself, I get strange noise, like a sqeaking noise, like metal rubbing when I go over speed bumps, was told it could be radiator mounts or ARB's, anyone could shed a little light?
    New Member badgerb's Avatar
    Nov 2009
    Oxford
    Try some silicon spray on the radiator mounts. Mine does this and I find a dab of spray helps no end. Should get around to replacing those mounts
    Sep 2009
    Warrington
    Quote Originally Posted by badgerb View Post
    What kinda price would replacing them be? Gonna have a peak tomorrow see where the mounts are.
  1. clunking
    By andy_richmond in forum Engine & Drivetrain
    Last Post: 17th November 2012, 18:52
  2. Clunking over bumps
    By Andy R in forum Vectra C / Signum Car Chat
    Last Post: 2nd September 2012, 13:12
  3. clunking noise
    By keggy77 in forum Engine & Drivetrain
    Last Post: 6th January 2012, 16:07
  4. Clunking noises?
    By mishima in forum Suspension, Wheels & Brakes
    Last Post: 30th September 2008, 13:25
  5. clunking n/s wheel
    By tash in forum Vectra C / Signum Car Chat
    Last Post: 21st April 2008, 21:27
vectra c loose radiator mount
