Results 1 to 10 of 19
Thread: Strange Problem....
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Default Strange Problem....
    Parked the car in the driveway today, then realising I was using the whole driveway I immediately climbed in and started the engine - except when I turnede the key to position 3 there was no noise - nothing.
    All the usual lights come on on the dash board and no warning lights. If I hold the key at position 3 for about 5 seconds the engine starts, but sometimes if the car is left for a while it will start no bother.
    I have checked the battery and it is showing a healthy 12.43V, does anyone know what this could be???
    Thanks,
    Gazza4
    cambs
    have you checked fuses and relays just in case
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by mhvcbv View Post
    What one bud??? Cant get the fusebox at the passenger door opened, seems shut solid.
    Gazza4
    cambs
    give it a good pull m8
    held in by metal clips
    Mileage : 000
    Yep. That fuse box cover can be a little hard to pull off.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by ed taylor View Post
    it wont do damage to remove the lid forcefully????
    Which fuse am i looking for??? Central Control Unit???
    Cheers guys,
    Gazza4
    Regular Member Chocki's Avatar
    Jul 2006
    Wolverhampton
    could be a sticking solenoid on the starter motor or a loose wire somewhere.
    cambs
    Quote Originally Posted by Gazza4 View Post
    Cheers guys,
    Gazza4
    no damage m8
    only you may brake a finger nail if your unlucky
    check fuse
    f7
    f9
    f10
    f18
    not to sure but its a start
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    no damage m8
    check fuse
    f7
    f9
    f10
    f18
    Cheers bud, havin a check
    Gazza4
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    These fuses are find bud, but curiously I dont have Fuse 18 - 'Ignition Terminal 15 Air Conditioning' --- What does that do??
    Air con works and ignition has always been fine without it
    Problem seems to have gone for the time being but I dont doubt it will be back.
    Cheers guys for all your help and suggestions.
    Gazza4
  1. Strange problem.
    By Chad! in forum Engine & Drivetrain
    Last Post: 13th October 2011, 14:18
  2. Strange problem
    By Graeme in forum Bodywork & Interior
    Last Post: 19th March 2011, 15:22
  3. Strange problem
    By kevster in forum Vectra C / Signum Car Chat
    Last Post: 25th January 2009, 12:59
  4. strange problem, help please
    By adamjukes01 in forum Engine & Drivetrain
    Last Post: 26th January 2008, 21:55
  5. Very Strange Problem
    By Ben H in forum Electrical & ICE (including SatNav)
    Last Post: 23rd October 2006, 17:32
