Thread: Vauxhall virgin havin problems
    Nov 2009
    Airdrie
    confused Vauxhall virgin havin problems
    Hi all, have recently bought an 04 plate 2.2 Dti Signum, it constantly loses power and revs as if the engine is starved of fuel, the engine management light comes on, after a few minutes the light will go off, revs return to normal and the car can be driven again for anything between 2mins and 2hrs before it does it again, can anyone tell me what the hells happening. Incidentally the previous owner has had a VXR exhaust fitted, dont know if this makes a difference.
    Regular Member OSSY's Avatar
    Apr 2009
    Have you checked to inlet manifold swirl valve rod?
    Not sure if this applys to your engine but if the funny shaped metal rod becomes displaced this could be causing your issues.
    But this may only apply to disel engines!!!
    Nov 2009
    Airdrie
    Cheers Ossy I'll check it out cos I really like this car and dont want to get a sickener an end up bein put off what is otherwise a crackin motor.
    West
    the above photo relates to the cdti unit not the dti...
    check the vac tube end connectors for splits, vac pumps to make sure there working & check for sticking egr... very common on all dti's
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    as DH says rob sounds like egr valve it's not much of a job to clean ,i do my signum on a 6 month service
    Regular Member pogo's Avatar
    Feb 2006
    Vehicle : Audi
    Trim : A5
    Engine : 2.0 turbo petrol
    hope its not the same prob my brother had with his signum rob he had the same symptoms as you and spent a fortune trying too sort it and never cured it ended up getting rid,is yours a 2.2 dti elegance on 04 plate by any chance in silver?
  1. Vauxhall Virgin
    By Lockstock2012 in forum Introduce yourself.
    Last Post: 28th August 2012, 19:50
  2. Vauxhall virgin
    By ridgers84 in forum Introduce yourself.
    Last Post: 21st January 2012, 23:33
  3. Vauxhall Virgin Acquires Signum 2.0DTi
    By ABS_Mouse in forum Introduce yourself.
    Last Post: 17th July 2010, 19:52
  4. havin it on the H!!!
    By big rich in forum The 'Off Topic' room
    Last Post: 7th August 2009, 12:14
  5. havin my baby
    Last Post: 2nd January 2009, 16:03
