View Poll Results: Do you get ANY vibration through clutch pedal
Voters
49. You may not vote on this poll
  • No I do not get any vibration/roughness thru clutch
    27 55.10%
  • Yes I do get vibration through clutch
    22 44.90%
Multiple Choice Poll.
Results 1 to 10 of 17
Thread: Clutch pedal vibration
    Oct 2009
    CRAWLEY,WEST SUSSEX
    Default Clutch pedal vibration
    Hi guys I posted this topic a couple of weeks back, but unfortunately through a misunderstanding got deleted!!
    Anyway I was asking if anyone gets any vibration,pulsating, or any feelings of roughness through their pedal.
    As the issue with mine is that mine has these symptoms.
    The story goes that when I bought the car ,57 plate 150CDTI SRI NAV estate, with 22k in september ,when I test drove the car I pointed out the clutch issue to the salesmen, he got one of the Technicians to test drive the car, who confirmed that there was an issue with the clutch or flywheel or release bearing, I bought the car a Network "Q" from a dealer an hours drive away from where I live, anyway I bought the car with a condition that the problem would be fixed at my local VX dealer under warranty.
    To cut a long story, the car was booked in at VX in Crawley, who had car for 2 days, when I collected car they told me that clutch and Dmf flywheel had both been replaced,as soon as I drove the car I felt little difference in clutch pedal. I took car back to them next morning, and explained my concerns that problem was'nt fixed, after waiting 20 minutes, a "technician" test drove the car and said that pedal vibration was normal,
    how can that be when technician at VX dealership where I bought car said it was a fault!!!!
    My view is that they have misdiagnosed fault which is probably the release bearing all along, and they will not put up hands and admit mistake
    By the way they would'nt supply a repair sheet detailing work carried , which in my view is essential for the vehicles history
    Please vote whether you get any vibration or feelings of roughness through clutch pedal, then maybe I can take this evidence back to vx
    Thanks for your time
    Cheers Ian
    hull
    I put a deposit on a 19cdti design last year, it had 110k on it and the seller told me the clutch/dmf had been changed at 105k. that also had some vibration through the clutch pedal which i presumed was normal for a deisel. after speaking to a mechanic pal he warned me away from it saying it wasn't normal and was probably the dmf.(on its way out or poor quality replacement)
    i kissed goodbye to my £100 deposit and ended up buying a 54 1.8 petrol sxi without the dmf probs associated with the cdti, and am happy.
    i would test drive another cdti if i were you to compare.
    Regular Member PeterVV's Avatar
    Oct 2007
    south wales
    The 1.8 `s are renown for it.........
    Oct 2009
    CRAWLEY,WEST SUSSEX
    Quote Originally Posted by PeterVV View Post
    Yes, but my car is'nt a 1.8 its a 1.9 diesel
    Come on guys 79 views and only 12 votes,I'm sure you can do better!!
    Cheers Ian
    WGAF#5
    Quote Originally Posted by Ianz View Post
    Cheers Ian
    Ian please take into consideration your thread title being "Clutch pedal vibration" = this would cause lots of people to "view" the thread hoping to help but on finding that it relates specifically to a 150CDTI then they may not have that type engine so therefore would have no requirement to vote (like myself) so you may recieve lots of views and only a few votes - but at least your poll would be accurate
    regards
    Dez
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    I have voted 'No'.
    I used to have this, only with the clutch lightly pressed, but since having the clutch and DMF replaced it has totally gone away, regardless of clutch position, in gear/out of gear etc.... no vibration at all.
    Oct 2009
    CRAWLEY,WEST SUSSEX
    I have voted 'No'.
    Dan thats exactly my issue , but I have had the DMF &clutch replaced and am still suffering the same symptoms, and do'nt want to be fobbed off with "its normal"
    Cheers Ian
    Oct 2009
    CRAWLEY,WEST SUSSEX
    regards
    Dez
    Apologies to all I had'nt seen it from that viewpoint!!
    Thanks to all that have voted & those that have viewed the post,
    I'll go and stand in the naughty corner!
    Cheers Ian
    Lancashire
    Trim : XP1
    Mileage : 66000
    Cheers Ian
    I have driven a few CDTi 120/150/V6 and its certainly not normal - like with mine it only do it where there was a fault.
    Regular Member barkzz's Avatar
    I dont get any vibration, but there is a slight change in tone half way up on the clutch.
    Wouldnt call it chattter, or a rattle, but something to be aware of.
    It's going back to VX over my continued issues with the juddering on idle. (Curiously it wasnt as bad with the BP ultimate diesel in the tank. I suspect dodgy injectors)
    So will be mentioning this, as i suspect if could be the start of the DMF/Clutch saga
  1. clutch pedal vibration,noisey
    By freelanderbri in forum Engine & Drivetrain
    Last Post: 19th November 2012, 14:30
  2. New clutch and DMF but still vibration in pedal
    By azacbr6 in forum Engine & Drivetrain
    Last Post: 29th September 2011, 16:54
  3. Clutch Pedal Vibration - 150 CDTi
    By Hopewell in forum Vectra C / Signum Car Chat
    Last Post: 7th April 2011, 14:28
