Thread: no reverse on my 1.9 cdti auto box
    Nov 2009
    leicester
    Default no reverse on my 1.9 cdti auto box
    recently bought a 55 plate vectra 1.9 cdti auto, all was fine until today when i selected reverse it didnt move, but when i select drive it goes through the gears fine and drives well, does this mean my gearbox is kna##ered or is this a fault that can be fixed. someone please help.
    Regular Member Lao's Avatar
    Aug 2009
    Romania, E.U.
    Vehicle : Vectra C Estate Automatic
    Trim : Elegance
    Don't know if this would help, but you might try it: do a software update on the gearbox. I just did mine Friday and went from 7500 to 10005 version (or something like that). Don't know how many in between, but it's better to have the last software. It's all done with Tech2, so you have to find someone that has it and that has acces to all updates. I also checked the ECU software, but I had the last version. Saved some cash.
    Regular Member cerbrious's Avatar
    Apr 2008
    Wigan
    does the reverse lights illuminate when you select reverse if not you might have a selector switch issue
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    or low oil level
    Nov 2009
    leicester
    Quote Originally Posted by cerbrious View Post
    yes when i select reverse the lights do illuminate, so does this mean it is a gearbox fault? could it be no oil as ive not checked or would that not make a difference.
    Nov 2009
    leicester
    or low oil level
    ive not checked oil yet but if it is low could that stop the reverse from working? ive saw a few posts saying that there was a dealer recall on these boxes do you know if this is true, they say it is something to do with the seal and water getting into the box and if it hasnt had new seals and water has got into the box then it will need to be replaced..... couldnt the box be taken off and just emptied.
    Nov 2009
    leicester
    Default can a 1.9 cdti auto box be changed to a manual box
    a few months ago i changed the auto box in a rover 25 (52 plate)stepspeed to a manual i just added flywheel and clutch, changed gear linkage and put in new pedal box all from the donor car it wasnt too difficult the only trouble i had was finding the wires for the inhibitor switch so i could start it but once i sorted that the started and car ran great............so has anyone or know of anyone that has converted the vectra 1.9 cdti auto into a manual ? or even know if this would be possible as i know the vectra is a bit more advanced than a rover 25.
    or to make my life easier does anyone know where there is an auto box for sale..... someone must have one !!!!!
    Regular Member MysteryElite's Avatar
    Feb 2007
    North Somerset
    Quote Originally Posted by matthughes73 View Post
    There was a recall to do with the cooler seals, but if you had that problem I'd expect more issues overall rather than just reverse. If water has got in its a rebuild or replace, as the contamination will destroy various components.
    I've seen this asked before and the general opinion was the complication with the electronics would be a nightmare - probably cost more than the car was worth.
    I'd check the auto transmission fluid level for sure. Have to say I don't remember seeing that issue on here - various problems with auto boxes and contamination but not where just reverse has gone.
    Aug 2009
    Romania, E.U.
    Trim : Elegance
    Start with the cheapest one: change the oil in the gearbox.
    Oct 2009
    CRAWLEY,WEST SUSSEX
    Quote Originally Posted by Lao View Post
    Cannot really understand how the issue would be lack of oil, as the car do'nt go in reverse, but does go forward, if it was an oil problem I would expect there to be issues using reverse & drive, its all the same oil afterall!!
    Cheers Ian
  1. Possible to add reverse parking sensor to a 1.9L 2008 CDti SRI?
    By therealkilkenny in forum Vectra C / Signum Car Chat
    Last Post: 13th March 2012, 23:27
  2. I have lost reverse on sri 150 cdti
    By shearzy in forum Vectra C / Signum Car Chat
    Last Post: 12th January 2010, 14:40
  3. 3.0 v6 CDTI AUTO BOX
    By SIDNUM in forum Vectra C / Signum Car Chat
    Last Post: 24th May 2009, 23:39
  4. Problem with 6 speed reverse (F40) CDTI
    By rushy in forum Engine & Drivetrain
    Last Post: 27th March 2008, 18:08
  5. Should I buy a V6 CDTI SRI AUTO?
    By Monza30 in forum Vectra C / Signum Car Chat
    Last Post: 24th February 2008, 15:50
vectra c automatic no reverse
