Results 1 to 10 of 11
Thread: engine on idle
    Regular Member The Gas Man's Avatar
    Feb 2006
    north east
    Default engine on idle
    i have a problem with my 1.8 , when the engine is on idle the revs go from about 500 to 750 constanly up and down , the lights and interior dash display also go brighter and dimmer, any thoughts
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    idle valve?
    Feb 2006
    north east
    thanks mate, so what is an idle valve and can i do it my self, does it need cleaning or is a replacement part needed,
    Mileage : 000
    Air control Valve. Do you have one on the side of the throttle body. It might need cleaning or even replacing. I am not too familier with the 1.8 vec C. But if it is like the 1.8 vec B. Then if there are some small holes on the inside of the throttle body you could try spraying some carb cleaner onto them. I used to have to do this on the wifes Vec B. It worked for a while. But in the end. I had to replace the air control valve, as a spring inside becomes weak and will not work proporly.
    Feb 2006
    north east
    thanks ed, i will have to have a look in the morning mate, not sure were the throttle body is will have to check the haynes manual
    Mileage : 000
    Quote Originally Posted by The Gas Man View Post
    The throttle body is the "thing" that the air intake pipe from the air filter box is conected to. It is basicly the inlet manifold. Try doing a search for " air control valve".
    Feb 2006
    north east
    cheers ed still not had a chance to look though
    Feb 2006
    north east
    got some carb cleaner gonna give it a go tomorow
    Regular Member carl bear's Avatar
    Burton on Trent, Midlands
    if that doesnt work , could be the EGR valve (if you have one, some 1.8's do, some dont).
    Mine was runnin slightly rough at idle turned out to be the egr valve.
    Regular Member barkzz's Avatar
    Quote Originally Posted by carl bear View Post
    1.8 with an EGR???
    Really? On a petrol? I've never heard of them having one, but i could be wrong, if so i stand corrected
  1. Engine won't idle! Help!
    Last Post: 5th December 2010, 17:43
  2. engine idle on the 150 cdti
    By rozzer2006 in forum Engine & Drivetrain
    Last Post: 11th January 2010, 20:21
  3. Replies: 4
    Last Post: 31st July 2008, 15:29
  4. engine idle speed help
    By jaxouk in forum Engine & Drivetrain
    Last Post: 17th April 2008, 20:57
  5. Engine Timing/Idle
    By Andy17899 in forum Vectra C / Signum Car Chat
    Last Post: 8th October 2007, 17:49
