Results 1 to 3 of 3
Thread: Wynns EGR3 spray - wow!
    Aug 2009
    herts
    Default Wynns EGR3 spray - wow!
    Well, a little while back I took off my EGR valve an gave it a clean! The side of the intake manifold it attached to was caked in thick soot.
    Not feeling confident to deal with the intake manifold, I left it well alone after an EGR facing surface clean out of the intake manifold and cleaning out of the EGR.
    All was put together, but still had the flat spot on 1st gear under 2k revs and also the wobbling/uneven idle.
    Read up on this Wynns EGR3 cleaner, did my research. It arrived yesterday, and today I chucked the stuff into my intake after the maf sensor by removing the flexi pipe and keeping the revs at 2k when spraying in. Some will disagree with this and state to put it in after the intercooler and poss at the point of entry for the intake manifold after the intercooler. I wasnt so technical so being wary of the maf sensor, I put it in the pipe left hand side of the engine, in a pipe after the flexi pipe between maf sensor and engine.
    It sounded horrible on being placed into the car, got a little alarmed, but persevered.
    NOW.......
    There is NO flatspot on 1st gear set off, and the idle does not wobble, it is smooth! My car is more perky and the turbo pulls stronger on acceleration. This now feels like a car I test drove in the dealership before buying my car privately...Result!
    I cant vouch for everyones experience of this product, only mine. My car 72k miles 150 cdti, egr has been cleaned out previously prior to this additive used.
    Go try it if you want to. I did, these were my results.
    Regular Member signum03's Avatar
    worthing
    how much was the cleaner bud and where from??
    Aug 2009
    herts
    Ebay search Wynns EGR3. About £10 a can incl p&p.
    The bottles are smaller than expected. A job requiring a good seeing to could benefit from 2 cans.
  1. Wynns Diesel EGR3 Air Intake & EGR System Cleaner
    By Gazz in forum Engine & Drivetrain
    Last Post: 11th October 2012, 07:46
  2. Wynn's EGR3 on a CDTI 150
    Last Post: 23rd September 2011, 19:32
  3. Wynns EGR3
    By MattW in forum Engine & Drivetrain
    Last Post: 7th March 2011, 09:41
  4. Wynns EGR3 any different from Carb Cleaner?
    By richardn in forum Engine & Drivetrain
    Last Post: 4th June 2010, 19:29
  5. wynns EGR3
    By den2712 in forum Vectra C / Signum Car Chat
    Last Post: 17th May 2010, 13:19
