Results 1 to 10 of 11
Thread: Registration Light
    Regular Member Clugie's Avatar
    Jun 2009
    Liverpool
    Unhappy Registration Light
    Anyone ever had a problem with these? i thaught i had a bulb out on one side so i decided to put LED bulbs in, one side was out put the new bulbs in an i still have one side out all the wires seem to be ok going into the socket thing were the bulb goes
    Any help an as much advice as possible would be much appreciated
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Did you put the bulb in the right way round? iirc led's only work one way
    Jun 2009
    Liverpool
    I did take the bulb out an turn it round but then I thaught I was bein stupid spinning the bulb round but it still didn't work when I done it
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Have you tried swapping the bulbs incase its a dodgy LED?
    Jun 2009
    Liverpool
    To be honest I havnt because I just thaught there must be a dodgy connection because the bulb was in there in the first place was alredy out
    Jun 2009
    Liverpool
    anyone else had problems??
    Regular Member yadziyad's Avatar
    London
    Quote Originally Posted by Clugie View Post
    ive had the same problem with me its the one on the passenger side im thinking of running the power from the drivers side to light the other one
    Jun 2009
    Liverpool
    Quote Originally Posted by yadziyad View Post
    Yer mine is the passenger side 1 aswell, if you do connect it up will you do a how too on it so i can do it? thanks
    Jun 2009
    Liverpool
    No one else had this problem??
    Nottinghamshire
    Not had a problem myself but I know that the wiring for the numberplate lights connects into the wiring loom at a multiplug that's located under the black plastic trim panel that runs along the bottom of the boot opening.
    If you can see the wiring colours at the bulb holders (so you can identify which wire is which) then perhaps you can use an electrical test meter to see if the power is getting as far as this connector?
  1. Registration light turned always on
    By banjokazooie in forum Vectra C / Signum Car Chat
    Last Post: 1st January 2011, 18:22
  2. Rear registration LED light
    By anthonychall in forum Vectra C / Signum Car Chat
    Last Post: 25th November 2009, 10:54
  3. Changing the back registration plate light bulb...
    By L11Marc in forum Vectra C / Signum Troubleshooting
    Last Post: 16th February 2009, 02:51
