Thread: knocking on start 2.dti
    London
    confused knocking on start 2.dti
    Hi
    I was trying to find answer for my problem but no result
    here is the situation
    1. Yesterday I had my DMF and CLUTCH been changed.
    2. I pick up my car when they were closing the garage so I couldn't resolve the issue.
    3. When I start and stop engine there is strong impact on chassis like engine want to jump out of the car. When is running is ok
    4. I suspect that they didnít tide the engine up properly to the mounts.
    I managed to ask them but they said that engine is sitting properly.
    5. Iím quite sure that there is smth loose because when Iím driving ďoff roadĒ there is strange knocking coming from the bottom
    Any suggestion please
    My main concern is if they could mess up smth with clutch and dmf fitting
    thank you
    Chris
    London
    Unhappy
    I was trying to find smth on forum no luck
    Please anyone
    Thank you
    Chris
    London
    Eek
    There is smth similar
    http://www.vectra-c.com/forum/showth...=engine+mounts
    but in my case
    first it wasn't like this before repair
    second is does exsessively
    Oct 2009
    Teesside
    Could they have knocked your crank sensor? or not replaced it correctly? Does it do it when warm etc?
    London
    yes it does
    no metter cold or warm everytime the same
    London
    Unhappy
    Sorted
    there was a engine's mount
    no knocking anymore
    but
    I was a very happy man before I hit a motorway
    during acceleration I noticed strong vibration really noticeable from 80m/h at 100 i need to hold steering wheel with both hands
    when i press a clutch vibration getting weaker
    taking under consideration that Iíve just changed clutch and DMF I start blaming that one
    Iíll try balance wheels 2morrow
    if they ok is there anyone with suggestions
    thank you
    Chris
    Regular Member Keithy's Avatar
    Jan 2008
    Dundee
    Quote Originally Posted by Krzysztof C. View Post
    Sorted
    no knocking anymore
    but
    thank you
    Chris
    That still sounds like an engine mount mate. I had the same problem with a vec b 2.5 v6. everything fine until about 60mph then it felt like inbalanced tyres but a lot worse. it turned out to be ther rear mount
    London
    Thank you
    but
    That what they checked 2day: all mounts
    They said that there was the top one playing
    So you think that even when I press clutch and vibration decrease it still maybe a mount not a clutch or DMF
    Sorry to be picky but you may save me some money on rebalancing
    Thank you
    Chris
    Jan 2008
    Dundee
    From what i can rember the virbration decreased when the clutch was depressed but the v6 petrol engine is a lot different than the 2.2 dti. So i might be barking up the wrong tree
    London
    no worries I will call them and take a car back to garage
    my concern is if faulty clutch or DMF may cause this kind of vibration?
    Thank you
    Chris
  1. 1.9 cdti knocking cold start
    By valleyboy in forum Engine & Drivetrain
    Last Post: 3rd January 2013, 23:23
  2. Knocking on cold start up 06 Vectra Club 1.9TDI
    By scottym23 in forum Vectra C / Signum Troubleshooting
    Last Post: 22nd November 2012, 13:30
  3. 1.8vvt knocking on start-up
    By w00dy in forum Engine & Drivetrain
    Last Post: 12th July 2011, 20:08
  4. Cars dead. Won't start. Fan runs when it would start.
    By baz_rochdale in forum Electrical & ICE (including SatNav)
    Last Post: 14th September 2010, 22:34
  5. still knocking
    By adfrodsham in forum Suspension, Wheels & Brakes
    Last Post: 31st January 2009, 10:34
Vectra dti knocking when trying to start
vectra knocking when starting site:www.vectra-c.com
