Thread: Buying a high mileage CDTI 150?
    St Neots
    Default Buying a high mileage CDTI 150?
    What are the drawbacks of buying a high mileage CDTI 150? The one i am looking at has covered 120k and says it has had the cambelt, DMF/clutch and inlet/swirl valve replaced. Is there anything else i should be warey of?
    Thanks Tom
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    thats about everything bud lol plus the altenator and the 3 injector lead are the common weakspots
    Regular Member vectrasri-j's Avatar
    Sep 2009
    luton
    Engine : 1.9 CDTI 120
    Mileage : 100000
    chrisvectra what is the weakspot on the 3rd injector lead and how do i check to see if my car is suffering from this??
    Are you VXR Enough
    13 Post(s)
    Quote Originally Posted by vectrasri-j View Post
    well when mine failed the eml light was on and the car would only run on 3 cylinders temp fix is to cable tie the lead tight or get the replacement lead from the stealers about 11 quid
    St Neots
    thanks buddy so if these expensive jobs have been done you wouldn't advise against it?
    West
    Tom,
    a mate of mine bought a preface 1.9 last year with 145k on the clock... he's still got it, it pulls really well & his only issue so far was a leaking shocker
    St Neots
    excellent thanks bud.
    i suppose the options are buy a low miler and expect to have those above parts replaced or buy a high miler and know they probably already have been done!
    Are you VXR Enough
    13 Post(s)
    dosnt matter what mileage the car has done bud as long as the parts mentioned have been done in the past as long as these have been replaced id buy the car if its in good nick to start with
    I agree
    Buy a low mileage at a higher cost and expect some wear and tear eventually
    OR
    Buy a high mileage at a lower cost and expect continual wear and tear failures
    I prefer the former with a long-term warranty (3 years / 120K miles)
    In the final year of ownership, once the warranty has expired, I then watch the costs
    I know there will be some, but in effect the car has paid for itself in the first three years
    Once it goes above £2000, or am advised a major repair bill is imminent, I start looking for a replacement
    It happened with my first Vectra B, the air con pump failed shortly after the warranty expired
    The book labour was four hours, but they did it in just under one hour (rather than strip the front of the car and lift it up, they just rotated it vetically and pulled it straight down), however the pump itself was £700
    At the next service I was advised the front suspension bushes were near the end of their life, and the quote was £1800
    Equally, a good time to sell the car "just serviced"
    Leicester
    If the items you have described have been replaced, then I would buy with confidence.
  1. Too high a mileage?
    By wi11 in forum Vectra C / Signum Car Chat
    Last Post: 15th March 2015, 18:13
  2. high mileage v6 cdti
    By JAY1 in forum Vectra C / Signum Car Chat
    Last Post: 22nd December 2008, 17:09
  3. High Mileage SRI CDTI 120
    By rocketship7081 in forum Vectra C / Signum Car Chat
    Last Post: 20th May 2008, 10:53
  4. High Mileage??
    By broadgates in forum Engine & Drivetrain
    Last Post: 28th February 2008, 18:55
  5. High mileage
    By cpt slow in forum Vectra C / Signum Car Chat
    Last Post: 3rd April 2006, 23:51
