Thread: Alternator problem?
    jilava
    Default Alternator problem?
    I noticed that the battery voltage with the engine started is 13.3 - 13.4V, never above that. Also the voltage with the engine off is 12.25V wich means about 50% charge, as I read on the internet somewhere. could this be an alternator/diode problem? Isn't the normal charge voltage 14,4V? it's a cdti 150bhp engine
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    How do you mean 50% charge mate, that sounds like an ok battery to me, batteries are only 12v.
    Sounds like the alternator is working perfectly too
    jilava
    I've read that a fully charged battery is 12,65V, at 12,45V is 75% charge, at 12,25V is 50% charge and if the battery is at 12V then it's practicly discharged wich is also bad for the battery. From what I've read a car (lead acid) battery should never be discharged more that 50%, that's lower than 12,25V.
    Regular Member Telly Addict's Avatar
    Sep 2009
    Fife
    Vehicle : BMW e92 335d
    Trim : M Sport
    Engine : 3.0 TT
    It's always possible that you've spotted an early warning sign of alternator failure. They are notorious on the CDTis.
    Might be prudent to start exploring avenues for possible repair/replacement.
    Wales
    Approx 14.4 volts would be about right for charging, as you need to overcome the batteries internal resistance to charge it.
  1. Alternator problem ?
    By Herman Villa in forum Vectra C / Signum Car Chat
    Last Post: 3rd September 2012, 19:36
  2. Alternator or Battery Problem?
    By bu_zz2020 in forum Electrical & ICE (including SatNav)
    Last Post: 1st April 2012, 20:03
  3. Alternator problem... Please help!
    By LiamGill in forum Engine & Drivetrain
    Last Post: 29th August 2011, 21:56
  4. Alternator problem
    By MistyMorning in forum Engine & Drivetrain
    Last Post: 25th January 2011, 10:20
  5. alternator problem
    By lloyd_456 in forum Electrical & ICE (including SatNav)
    Last Post: 19th October 2009, 14:22
vectra signs of alternator problems
