Results 1 to 3 of 3
Thread: need some help
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    Default need some help
    can somebody give me a list of things that i can check on rear suspention, gonna give mine a good going over tomorrow, still getting knock knock noise and in defo gonna sort out where its coming from, (if it dont rain)
    East Midlands
    Right m8..before you jack your car up do the 12 oclock ,6 oclock test ,if there's any movement in the wheel its self or you feel it knocking,this indicates rear upper control arm bushes cream crackered..cheapish fix with How Too on here point you in right direction.
    People me included have had probs with the oem shockers,which seem to make the car step out a little when going over pot holes...easy fix.
    Thirdly.Worn anti roll bar bushes ,again cheap to fix and well within the scope of a DIYer,look on here for How Too.
    And last but not least. roll bar drop links. HTH.
    ps ..the knock knock noise sounds like the upper control arms bud
    Oct 2009
    Sandwell
    cheers MACDAD , i only get the noise now and again not on every speed hump but the noise seems to have got worse over time started off like parcel shelf was knocking but its got louder
