Thread: Fuel Warning
    Leicester
    Default Fuel Warning
    Guys, I received some interesting info yesterday from a customer of mine who works at a refinery in the UK.
    This is about unleaded fuel. From the beginning of December, European legislation has changed to say that all unleaded fuel must have 5% Ethenol mixed in. I have read about this ages ago. However, this is causing issues.
    Sainsbury are already using this and the filters in the storage systems are blocking at an alarming rate.
    If I have got this right, Ethenol is in effect plant based there is alot of water content in the make up of the fuel. The problem that has been occuring is that when mixed, it can absorb the moisture in the air of the tank and after a period of time the fuel starts to separate in the fuel tanks on the forecourts. This of course is not good if pumped into your petrol tank.
    It is expected that this will cause running issues of petrol cars and irratic running and a little loss of power is expected. From what I was told, it could take until next spring to sort the problem out. The Americans had this issue but have got past it.
    So be very careful. There is one solution though, apparently you can't mix super unleaded with ethanol as the octane rating it effected. So to get by until it's all sorted his advice is to run on super.
    Morrisons - Avoid Morrisons diesel, they are still buying summer diesel instead of winter diesel now. Summer is cheaper to buy whole sale but as it does not have the ingredient to stop waxing in winter months. Their fuel is the lowest grade of diesel you are allowed to use in the UK, it conforms to BS but right at the bottom end.
    Hope this helps
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP NAV
    Engine : 1.9 CDTi 150
    Very interesting info, thanks for that.
    Handy to know for the wifes Laguna.
    Regular Member Keithy's Avatar
    Jan 2008
    Dundee
    yeah i agree. thanks for that
    Regular Member Thunder's Avatar
    Apr 2008
    North Yorkshire
    Vehicle : Vectra C Facelift
    Engine : CDTi 150
    Mileage : 71000
    Cheers for the info
    WGAF#5
    always nice to know what problems can arise just by fuelling your car a relatively simple operation that they seem to keep complicating and of course you can expect to pay more for the benefit of them adding ethanol
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Thanks for the info much appreciated.
    and still loving it
    Regular Member mattDY57's Avatar
    Yorkshire
    This has been available in France alongside normal unleaded since the start of the year.Before we went over this summer in the vec I emailed Vauxhall about whether it was ok to use this new fuel. I expected an email back saying it was ok to use, but they RANG me up to say NO NO NO!
    Regular Member Danialj32's Avatar
    Sep 2009
    Warrington
    So is it worth paying that little bit extra for the super unleaded for us petrol heads?
    VOTING UKIP IN AVELEY
    5 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    cheers for the heads up Matt................glad i use S.U so wont have to shell out any extra £
    Jun 2009
    Co. Durham
    Cheers for the heads-up.
  1. fuel warning
    Last Post: 28th December 2012, 15:17
  2. '03 DTI - Do I Have a Low Fuel Warning Light?
    By AdeV6 in forum Vectra C / Signum Car Chat
    Last Post: 28th May 2012, 10:43
  3. Fuel level warning light......
    By Nik in forum Electrical & ICE (including SatNav)
    Last Post: 20th July 2011, 00:44
  4. Fuel warning on radio incorrect.
    By anthonychall in forum Engine & Drivetrain
    Last Post: 26th August 2009, 20:54
  5. B30 Bio Diesel Fuel Warning
    Last Post: 17th December 2008, 19:18
