Thread: cdti turbo not kicking in
    Oct 2009
    CHEADLE HULME
    Unhappy cdti turbo not kicking in
    i have a 2005 cdti(150) and it runs perfect most of the time but every now and again it juders when the boost should be kicking in and i have no power sometimes it will just do it once then be ok and sometimes it will last maybe five or ten minutes then it will just go back to normal! ive had the filters changed and it made no difference ive also had a diagnostics check that showed no faults. The engine management warning light doesnt come on when it happens!!!
    Bristol
    Vehicle : CDTI 150
    Check the rubber pipes that feed the turbo for splits.
    Oct 2009
    Machynlleth
    My Vw Passat did it. Found out to be a split hose.
    Full Member GazVXLINE170's Avatar
    Jun 2007
    Scotland
    Vehicle : Insignia
    Trim : SRI VX-Line Nav
    Engine : 2.0 CDTI [170 PS]
    Year : 2015
    Mileage : 27000
    Had the exact same problem - Bust inetercooler. but it is most likely a bust hose somewhere.
    Gazza4
    Insignia VX-Line Nav CDTI 170.
    Regular Member signum03's Avatar
    worthing
    derbyshire
    had same problem cleaned egr and found small split in the small pipe to the turbo problem solved
  1. 1.9 CDTi turbo not kicking in till 2400rpm
    By Ginge7289 in forum Engine & Drivetrain
    Last Post: 12th December 2011, 10:41
  2. car kicking out smoke
    By coooky in forum Engine & Drivetrain
    Last Post: 19th August 2011, 20:47
  3. Back end kicking out
    By Juego in forum Handling & Braking
    Last Post: 29th April 2011, 22:06
  4. 20k revs then kicking in to 30k
    By richje100 in forum Engine & Drivetrain
    Last Post: 27th April 2011, 16:43
  5. I bet hes kicking himself now...
    By rob 2.2dti in forum Comedy & Humour
    Last Post: 10th February 2009, 20:09
