Results 1 to 10 of 13
Thread: oil light flickers
    Sep 2009
    essex
    Default oil light flickers
    Hi all,
    I have a 53 vectra 2.2dti, after the engine is fully warm the oil warning light on the dash flickers, I have changed the oil and filter.
    Anyone have any ideas on what it could be or anyone had anything similar?
    any advise would be much appreciated...
    steve
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Have you put enough oil in? The oil should be checked warm on a DTi
    Full Member Big Sig's Avatar
    Also what grade of oil was it? Did the light flash before?
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Very good point although I run 0w-30 in my dti and thats about as thin as you can get and have no lights. Although it could be a faulty oil pressure switch
    Yes, but no two engines are the same.
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Quote Originally Posted by luckyracer View Post
    Hi all,
    steve
    On re-reading what you have written you say you changed the oil, was this an attempt to cure the flickering light? Also what warning light is it? The pressure light or the oil level light
    Thats it John, keep it up
    Sep 2009
    essex
    Thanks for the interest guys, I changed the oil to try and cure the problem, I have checked the levels and they are fine, its the oil light that comes on with the ignition, the oil level warning light I assume.
    It only does it when the engine is really warm and when idling, the second I touch the accelerator to pick up the revs it goes out.
    Glasgow
    Maybe the oil pump!?!
    Sep 2009
    essex
    Just an update, I had the drive belt tensioner go the other day, the car ended up in the stealers, thought that may be a fix for this, but ...no. is still doing it, when I pick up the revs even the slightest amount the oil light goes out... so dont think it is the oil pump.. is the oil pressure, or level switch the sensor at the bottom of the sump?
  1. Original xenon (AFL) flickers and sometimes blacks out
    By Thomza in forum Electrical & ICE (including SatNav)
    Last Post: 7th January 2013, 16:57
  2. Replies: 4
    Last Post: 18th August 2012, 08:58
  3. Replies: 17
    Last Post: 16th August 2012, 10:07
  4. PLEEEEASE HELP - traction control light/power steering light on!!!
    By holdenvectra in forum Electrical & ICE (including SatNav)
    Last Post: 28th June 2010, 23:39
  5. Fitted rear light,illuminated sunvisors and map reading light
    By glenboy in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2008, 10:51
