Thread: what oil
    manchester
    Default what oil
    what oil is best for my 2.2 direct 2005,its done 80000 miles,its also a taxi so does a lot of miles,got 10/40 in it with evry service(every 10000miles) but the oil does not last long,whats best for high miles.cheers in advance rick
    Regular Member keith1983's Avatar
    Sheffield / Spalding
    Vehicle : Vectra 1.8 SRi
    Engine : Z18XE
    what do you mean by it doesn't last long? Is the level going down quickly or is it getting dirty and grimey quickly?
    manchester
    it goes thinner quicker and uses about a litre every 8to10 weeks cheers
    Engine : Z18XE
    that sounds like alot but then I can only speak from experience in my 1.8 Im sure a fellow 2.2 owner will be along soon to point you in the right direction.
    manchester
    cheers mate,theres always someone on here with an answer
    Regular Member Dose's Avatar
    Falkirk/dunfermline/alloa
    5w30 fully synthetic irrc.
    11 Post(s)
    Quote Originally Posted by rick1965 View Post
    And what is that in mileage terms? Being a taxi, I imagine quite a few.
    No two engines are alike. Some will use oil, others won't. My previous 2.2 (53 reg) used approx 1 litre every 2,500 miles (wrote the car off at 36,000 miles), whereas my current 2.2 (06 reg - currently on 44,000 miles) doesn't use a drop in 10,000 to 11,000 miles (my average yearly mileage when I get it serviced).
    As said, 5w/30 fully synth is the recommended oil, but some people suggest the 10w/40 semi synth if you're doing regular oil changes or have a high mileage engine.
    Oh, btw, Vauxhall (and other manufacturers) mention in the handbook that an engine can use a litre of oil every 1000 miles.
    Full Member Big Sig's Avatar
    IIRC the 2.2's do tend to use a bit of oil anyway.
