Results 1 to 10 of 20
Thread: Traction controll
    Sep 2009
    Glasgow
    Default Traction controll
    Does my vectra c 55 facelift sri have traction controll , the dash icon lights up apon startup and goes back out, but i have spun the wheels a few times over the last few weeks and didn't notice the light on, might get the traction controll switch once i check i have the connector behind the blanking plate.
    Regular Member paul.sessions's Avatar
    leighton buzzard
    should have
    Oct 2006
    Waterloo, Liverpool
    13 Post(s)
    Trim : DESIGN
    Engine : 1.5T (165)
    Year : 2018
    Mileage : 220
    Some early facelifts with non-V6 engines, and not 1.8 petrols, were fitted with traction control. After that, only V6-engined cars had TC, as part of their standard ESP option. As yours is a 55-plater it probably has got TC. Hence the symbol on the dash, which should appear briefly and then go out (at the same time as the ABS symbol) when you switch the ignition on.
    Sep 2009
    Glasgow
    i'm assuming standard wheel spin from standing start would activate tc and light up the dash, if so i'll give it a try tommorrow, as i explained in first post while driving last few weeks i have spun wheels a couple of times but was busy watching the road but both times it was in the dark but maybee i just missed it flashing on and off.
    Leicester
    Quote Originally Posted by nokiaman1978 View Post
    Cars built after 26th October 2005 were stripped of there traction control system. Only 2.0Turbo and all V6 models had TC as standard. Other models got TC as part of the optional ESP+ package.
    You will have the plugs behind the switch blank but your switch won't work as your car is full canbus. All dash's have the same loom so your blue/green connector will be there but it won't do anything.
    The traction control will let the wheels spin a little.
    A 1.9 CDTI SRI shouldn't have TC
    However, if the optional extra ESP has been added then it will show on pre-engine start
    Leicester
    All 1.9 CDTi's had traction control as standard up until 26th October 2005. As said above, cars built after this time did not, it was put on the options list. My first 1.9 had it and Spoon's SRi had it.
    Regular Member Thunder's Avatar
    Apr 2008
    North Yorkshire
    Vehicle : Vectra C Facelift
    Engine : CDTi 150
    Mileage : 71000
    Mine has it too
    registered on 10/10/2005
    Best place to test is on big open space and get on some wet grass or mud & then put your foot down
    Sep 2009
    Glasgow
    so from the info so far i can assume because i have the tc controll light up on start of engine tc is active and has been installed as an optional extra and cars after 26 th oct don't have tc and on start up wont display tc light.
    Regular Member robk6112's Avatar
    Halifax
    My 1.9 sri has it reg date 10/01/05 what else eas removed in ocotber 05 then?
    I know mine doesnt have chrome window strips
  1. Has anyone got a climate controll resistor or know where I can get a second hand one
    By CallumHill in forum Vectra C / Signum Troubleshooting
    Last Post: 28th December 2012, 20:29
  2. traction controll switch
    By dansri in forum Vectra C / Signum Car Chat
    Last Post: 17th November 2010, 01:37
  3. BC with CD30 and GID cant controll anything
    By blakewp in forum Electrical & ICE (including SatNav)
    Last Post: 11th February 2009, 00:43
  4. Traction Control
    By Hs2300 in forum Engine & Drivetrain
    Last Post: 6th November 2008, 00:15
  5. Traction controll button
    By lindsay1411 in forum Vectra C / Signum Car Chat
    Last Post: 12th August 2007, 01:38
