Results 1 to 10 of 13
Thread: 03 vectra 1.8 emissions light and rough idle
    Nov 2009
    MIDDLESBROUGH
    confused 03 vectra 1.8 emissions light and rough idle
    MY 03 VECTRA 1.8 IS 'LUMPY ON IDLE BUT SEEMS TO RUN OK ON LONG RUNS TO SCOTLAND 2x A MONTH. EMISSIONS LIGHT IS ON ALL THE TIME.
    Any advice welcome - I am thinking of cleaning out the EGR valve.
    'blink code' methods indicate
    1405 -DPFE sensor upstream hose off or plugged
    0170 fuel trim malfunction (bank 1)
    Thank you in advance
    Ian G
    Regular Member danBoy's Avatar
    Jun 2006
    Northampton
    The Vectra C 1.8 doesn't have an EGR valve, its all controlled by the throttle body.
    Worcs/Staffs/Westmids (ish)
    Lambda sensor?
    Nov 2009
    MIDDLESBROUGH
    Default No EGR ?
    No EGR eh? I was charged £200 3 years ago for a diagnostic and a new gas return valve.
    No wonder I am loathe to go back to a garage.
    Would a faulty lambda sensor cause engine to idle/tick over erraticly?
    Quote Originally Posted by danBoy View Post
    Yes it does, 95% sure its on the front offside. Metal can type affair. I believe we cleaned Payneys at PVS.
    Nov 2009
    MIDDLESBROUGH
    Thanks Big Sig
    Quote Originally Posted by likeit40 View Post
    Yes, very much so.... The ECU can't work out the fuel/air mixture because it's getting wrong emissions info from the sensor. As it gets worse it'll get to the point where the engine tries to stall at every junction.
    Generally speaking it would either cause over fueling or lean running, over fueling will eventually damage the piston rings (due to dilution of the engine oil) while lean running will cause overheating (but nothing the cooling system can't handle).
    I "lost" a lambda sensor on my last car and 3 different garages couldn't work out what the problem was, one "recommended" chap even told me my exhaust must blocked (because it was getting far too hot).... Nothing to do of course with the engine running lean
    If it's the lambda sensor, then the ECU will have recorded a faulty condition flag..... I would be inclined to get it checked out by VX.
    Regular Member carpet's Avatar
    Jul 2006
    TENTERDEN KENT
    1.8s DO have an EGR valve, open bonnet, remove engine cover, look at right hand end of engine by the battery cover, small dustbin like object with a connector on top, this the ERG valve. Held on by two screws.
    May 2008
    Tyneside
    My 03 reg 1.8ls doesn't have one, I read somewhere the 1.8 engine does not require one as it easily meets the emmissions regs. Vaux may have fitted one on later models though.
    New Member badgerb's Avatar
    Nov 2009
    Oxford
    Likeit - did you mange to get this sorted, this evening my car has flagged up exactly that same errors as yours P Codes 0170 and 1405.
  1. 2.8T rough idle
    By donkmeister in forum Engine & Drivetrain
    Last Post: 5th December 2012, 12:07
  2. vectra gsi running rough misfires high idle
    By shaunft in forum Engine & Drivetrain
    Last Post: 9th August 2012, 23:03
  3. VECTRA SRI CDTi 150 1.9 ROUGH IDLE
    By nafmughal in forum Vectra C / Signum Troubleshooting
    Last Post: 15th January 2010, 23:23
  4. rough idle
    By ERIC in forum Engine & Drivetrain
    Last Post: 14th November 2008, 22:40
  5. Rough idle on GSI
    By rayvo-gsi in forum Engine & Drivetrain
    Last Post: 18th April 2008, 17:41
vectra c 1.8 running rough
vectra c erratic idle
vectra c 1.8 rough idle
vectra c rough idle
vectra c 1.8 petrol egr valve
vauxhall vectra c 1.8xer running lean
petrol 1.8 vectra c egr valve symptoms
vectra rough idlevectra c 1.8 egr valve removalvectra emmissions light onvectra 1.8 unevenvectra c idle fluctuatesinsignia 1.8 rough runningvectra c idles rough intil warmvauxhall vectra lumpy idleopel vectra rough idlevectra c lumpy idlevectra c 1.8 idle fluctuating vectra c 1.8 misfire ems light onvectra 3 emission light onvectra c 1.8 emmission light onvectra c idle fluctuating www.vectra-c.com2006 vauxhall vectra 1.8 rough idlevauxhall vectra 08 idle roughly insignia 1.8 xer poor idel
