Results 1 to 10 of 19
Thread: turbo bypass valve
    Regular Member stuartbat's Avatar
    May 2008
    shropshire
    Default turbo bypass valve
    Okay guys just had a a code read on my 2.0 turbo veccy and i have been told that the turbo bypass valve was showing that it had a error.
    Now excatly what does this do?
    How much are they?
    Is it a easy job to change
    Is it a serviceable part?
    it isnt like a dump vavle i take it
    May 2008
    shropshire
    any 1 ? can i just replace it with a dump valve?
    WGAF#5
    can you post the fault code to give us a better idea of what the fault would relate to ?? has the cars engine management light come on
    - have you experienced any loss of performance - have you changed your fuel supplier, any unusual noises???
    if you can answer the above then i'm fairly sure we can give you a little more back
    regards
    Dez
    May 2008
    shropshire
    i dont know what the fault code was all the garage have told me is that the recorded fault code was for the turbo bypass valve.
    the engine light did come on for a short while on the wife
    then when i was driving the car the day after there was no boost of the turbo as the car was as slow as my corsa however after a few stop starts the turbo started boosting again .
    Hope this help i have look on google and it appears that the bypass valve is the same as a dump valve so can i just fit a nice forge item?
    Regular Member Jezzy's Avatar
    S.E
    Part number 55354158, about £25 from Vauxhall dealers; same part number for Saab dealers who are more likely to have it in stock (it is a Saab engine after all).
    S.E
    Here's what Wiki says about dumpvalves and bypass valves:
    A bypass valve is a more elegant solution to this problem by allowing the turbo to "freewheel" when the throttle is closed (equalizing the pressure on both sides of the turbo). Unlike a dump valve a bypass valve can be used at multiple boost settings without reconfiguration. bypass valves are sometimes incorrectly called dump valves because they serve a similar function, but they are very different solutions to the same problem.
    S.E
    Had another thought on whether you can use a dump valve instead of the bypass valve - the ECU would still recognise the bypass valve as either broken or missing, so would probably put the engine into limp mode.
    May 2008
    shropshire
    kewl thanks for that guys so when i get the problem again then ill just go and get a new 1 from the stealers
    Apr 2009
    shrewsbury
    Hope you dont mind me jumping in here.
    I have also the same fault on my 2.0T the code is P0034.
    The symptoms are exactly the same.
    Refferrring to this By-Pass valve, can someone shed some light on to where it is located on the engine?
    After googling for an hour it seems the rubber diaphram is prone to go on these, so if some one could point me in the right direction i will do a how to guide for future reference on both how to replace the diaphram and also the whole unit. Personally i will probably fit an aftermarket one with springs and pistons rather than rubber.
    Thanks,
    Mark.
    May 2008
    shropshire
    and its playing up again lol
    any 1 got a how to or can put up some steps on how to repalce it thx
  1. V6CDTi coolant loss - heater bypass valve?
    By Celes in forum Engine & Drivetrain
    Last Post: 6th October 2010, 17:50
  2. Blowoff valve for 2.0 turbo
    By Mrsan in forum Tuning
    Last Post: 20th February 2008, 21:08
  3. where do you get the dump valve for the 2.0 turbo??
    By bobtheboss78 in forum Petrol Engine related
    Last Post: 15th December 2007, 09:45
  4. Blow off valve for non turbo?
    By Matt21385 in forum Tuning
    Last Post: 3rd April 2006, 08:00
  5. SRI 2.0 Turbo Dump Valve????
    By bobbin in forum Vectra C / Signum Car Chat
    Last Post: 20th September 2005, 17:55
bypass ventil opel vectra
turbo bypass valve vauxhall vectra c
vectra turbo bypass valve
vauxhall turbo bypass valve
