Thread: corsa-c timing chain
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Default corsa-c timing chain
    anyone done a timing chain on a corsa-c 1.2 ?, the lads 2001 y 1.2 is starting to be noisy when hot, advise gained points to timing chain, a pointer to a how to would be nice if anyone has put one up elsewhere.
    Regular Member paul wingnut's Avatar
    durham
    Vehicle : vectra sri 150
    Engine : 1900 cdti 150
    first of all you would need timing tools can be bought from independant .need to remove rocker cover and front pipe and sump support engine take off engine mount alt belt waterpump pulley and alternator and tensioner time up engine no 1 cyl at top slots in cams horizontal fit cam tool in slots on front of engine near timing chain side torq head nut t55 remove crank pin fits there when timed up remove t 18 bolt from crank pulley middle bolt slide off pulley remove all t 10 bolts note different lenghts water pump ones loonger 5 of them remove timing case then easy to work out dont loosen cam pulley bolts if you are just fitting chain and guides fit new gasket first before chain hope this helps......will take about 1/2 day to do if every thing comes off ok
    Glasgow
    Do we have a VX technician here lol
    durham
    unfortunatly yeah someone got to fix them lol.
    Glasgow
    You must do a helluva lot of those corsa timing chains, the amount of corsa's running around sounding like tractors is unbelievable.
    You should have kept that quiet your pm inbox will be full by the morning
    Regular Member Dose's Avatar
    Falkirk/dunfermline/alloa
    1/2 a day is that for a diyer? i would get sacked if it took me that long?
    durham
    yeah same hear you could do it in a couple of hours but some one who hasn't done one and at home without air tools going to be about 1/2day job i think standard time is about 5 hours
  1. Timing chain
    By signumboy in forum Engine & Drivetrain
    Last Post: 11th August 2011, 18:19
  2. corsa 1.2 timing chain
    By marktaylor in forum The 'Off Topic' room
    Last Post: 12th July 2011, 09:18
  3. Timing chain on a corsa
    By johnnyboy1985 in forum The 'Off Topic' room
    Last Post: 2nd May 2011, 09:11
  4. timing chain
    By barneyp06 in forum Vectra C / Signum Car Chat
    Last Post: 28th July 2010, 11:04
  5. timing chain
    By gsp1 in forum Engine & Drivetrain
    Last Post: 25th May 2009, 23:13
