Results 1 to 10 of 11
Thread: xbox
    Regular Member SRimonkey's Avatar
    wednesfield
    Default xbox
    brother in law`s told me his xbox has packed in........it`s only 18 months old,he`s gonna bring it round 4 me in a while,i know nothin at all about xboxes but read ya can sort of read fault codes off the red lights at the front,so depending on whats wrong with it.......can we get microsoft to sort it out for him??????????
    cheers lads
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    IIRC 360's have a long warranty period due to high failure rate, you should be able to gt Microsoft to sort this out for him.
    wednesfield
    if it was 3 red lights mate i would of repaired this for a small charge of £30
    but 2 red lights is a hit and miss
    i would put tape on the rear or the 360 to stop the heat getting out and wrap it in a towel (keep a very close eye on it) and make it over heat giving it 3 red lights then send back to M$ for free repair as 3 red lights is under 3 year warranty
    or just send it back saying it comes up with 3 red lights to be fair i doubt they even check them i know on at least 2 360's i have sent back its a replacement and not the 1 i sent that arrived back with me
    you say its 2 red lights can you read the code
    The specific type of hardware failure can be determined by a "hidden" error code
    Turn the xbox 360 on, and wait till the 3 red lights are flashing.
    Press and hold the sync up button (the small white one), while holding that button press the eject button.
    The LEDs will now blink the first number in the code (as described below).
    Release the eject button and press it again.
    The LEDs will now blink the second number of the code.
    The LEDs will now blink the third number of the code.
    The LEDs will now blink the forth number of the code.
    The LEDs will go back to the 3 red flashing lights.
    You should be able to determine the difference between the 3 flashing lights and the error code lights by the rate in which they flash.
    Here is how you interpret the LEDs to get the code number:
    All four lights flashing - 0
    One light flashing - 1
    Two Lights flashing - 2
    Three lights flashing - 3
    0001 power supply problem
    0002 Network Interface problem
    0003 Power problem could be the PSU could be the GPU/CPU, somehow the console isn't getting clean power from the power supply.
    0010 over heating
    0011 over heating - If you are receiving this error after disassembling your console make sure to all 8 of the heatsync screws are tightened securely to the board/heatsink holes.
    0012 over heating
    0013 over heating
    0020 (Not yet known, possibly overheating)
    0021 DVD Drive Time out - Can be caused by problems with a firmware flash. This is also speculated to sometime be caused by a problem with the southbridge chipset on the motherboard.
    0022 GPU Error / GPU Overheating
    0023 (not yet known)
    0101 (not yet known)
    0102 unknown error
    though it's most likely GPU related literally means the console does not know what is wrong. possibly a short or cold solder joint somewhere. So far there is 1 major theory for what causes most of these errors is that the Ram, CPU, or GPU are not soldered properly to the mother board due either to poor manufacturing or excessive heat up and cool down cycles that stress, weaken and eventually break the soldered connection.
    There are two theories to fixing this one deals with the "X" clamps that hold down the chips. The other involves re-Heating the chips. DO NOT attempt either of these if your console is still under warranty. If your console is still under warranty return it to the store where it was purchased or call MS to have it replaced. I have also heard of limited success by simply switching the AV cable from "HDTV" mode to "TV" mode.
    0103 CPU Error/ CPU Overheating - see solution for error 0102
    0110 Memory Error / Memory Overheating - see solution for error 0102
    0200 (not yet known)
    1000 (not yet known)
    1001 (not yet known)
    1002 (not yet known)
    1003 Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it
    1010 Hard Drive Error, Can be caused buy a corrupt or missing eProm.
    1011 (not yet known)
    1012 (not yet known)
    1013 (not yet known) possibly a dashboard update error
    1020 (not yet known)
    1021 (not yet known)
    1022 AV cable error... There is a problem with the AV cable, try using a different AV cable. (could also be a problem with the encoder chip)
    1023 DVD drive not connected, connect DVD drive to boot
    1030 (not yet known)
    1031 (not yet known)
    1032 (not yet known)
    1033 (not yet known)
    1444 and up There is no "4" in the error codes four lights is a "0" go back and check your code again
    just found this in another post on here.......might just cook the thing,all depends on what codes it gives out
    WGAF#5
    if its 3 lights then microsoft will repair free of charge for 3 years as per their own website
    wednesfield
    he`s bringing it round in a bit but he says he got sound but no video and the console not displaying any faults
    Plymouth
    ROFL...
    this happend to me...
    to fix was a pain in the ass..
    I had to plug the lead into the back properly as it was loose
    wednesfield
    wouldn`t surprise me m8
    wednesfield
    right i`ve got the xbox here no..........it works,no errors or red rings..............but nothing on the screen but i can hear the cod intro......help lads
    Full Member Big-Pete's Avatar
    May 2007
    Home or in the Gym
    96 Post(s)
    Vehicle : Audi Q7
    Trim : S-Line Plus 245
    Engine : 3.0 TDV6
    Mileage : 3023
    I wouldnt bother messing about with it, Just call MS and tell them you have 3 red lights instead of one green light, and then when they ask you what colour the LED is on the PSU tell them its green when you power the 360 up and it goes to amber when you turn the 360 off, they should then email or post out to you some courier labels....
    Regular Member Grahamy's Avatar
    Ryton
    microsoft today have put a block on some xbox's gaming because owners have chipped the box's so they can play copied games, dont know how ms can tell but they can.
    http://news.bbc.co.uk/1/hi/technology/8354166.stm
  1. Which Xbox?
    By jonesy_ni in forum Games Room
    Last Post: 22nd December 2008, 15:20
  2. Better than an Xbox
    By MLC in forum General Chat
    Last Post: 4th November 2007, 22:57
  3. xbox 360
    By big peachy in forum Games Room
    Last Post: 19th December 2005, 13:12
