Page 1 of 4 123 ... LastLast
Results 1 to 10 of 40
Thread: Low end power is still not there!
    Regular Member larrysSRI's Avatar
    Nov 2009
    south wales
    Default Low end power is still not there!
    After all the advice you guys have given me i have just cleaned the EGR valve. The solenoid was moving freely so did not need to sort that out.
    I did the 3rd injector too and have also cleaned the boost sensor although i cant see the yellow sensor inside it although its clean.
    After all this the car is still the same.
    The inlet manifold definately looks new and was not clogged up when i checked it.
    My brother in-law (VXR CDTI) said that his vectra (same engine) used to pull strong from alot lower than 2500 like mine does so there is defo something wrong.
    Is there a way of testing if the boost is working properly?
    Nov 2009
    south wales
    Also, i seem to notice that the engine temp never goes above 80 on the dial and it takes a very long time to get there?
    Could this be anything to do with it?
    Admin & Merchandise Manager bigmac's Avatar
    Devon
    72 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Diesels take ages to warm up so i wouldn't worry,regarding your other problem i would check all hoses for splits or cracks
    Irmscher Insignia CDTI 130
    What engine do you have?
    Most VX diesels have poor "power" until 2000rpm
    If your revs are less than 2000rpm then you will need to change down one gear if you want more "power"
    The power band is typically 2300 to 3500rpm
    However, diesels aren't about power, they are about torque
    The power is there, its just that the gear ratios mean it takes much longer to accelerate
    If you have come from driving petrols then you need to retrain yourself on how to drive for "power"
    Nov 2009
    south wales
    I have been driving for 18 yrs and have owned various petrol and diesel cars, have been brought up with a motoring background, so im quite familier with different driving styles needed for different cars.
    The issue is that the car is not performing right in lower revs and i am trying to solve the issue. (test drove by a previous 1.9 cdti 150 owner)
    If putting your foot down at 30mph in third gear and almost going backwards is correct then yes i need to learn to drive again
    The manual states peak torque is between 2000-2750rpm.
    I have previously owned a vectra b 2.2 sri dti and it would p**s all over this one till 3000rpm.
    Nov 2009
    south wales
    Quote Originally Posted by bigmac View Post
    Cheers.
    Will check them over tomorrow after i have stripped the egr solenoid and fitted my K&N panel filter.
    Have some Wynns EGR3 and Deisel injector cleaner on order which i hope will help clean a few internal parts.
    I cant understand how after 3000revs the car flys, with no flat spots, hesitating or even a cloud of smoke.
    If the turbo was packing up what would the symptoms be?
    Sep 2009
    Swindon
    What's the mileage on the car? I have just removed the turbo from my car and found it to be full of carbon and not operating correctely, I will refit this weekend and check what performance difference it makes.
    My friend who test drove the car for me (mechanic) reckons that the MAF is also suspect as the car is really flat, especially below 2000 rpm, trouble is they are about £100 so I want to be sure before buying a new one. Basically the vanes on my turbo were stuck in one position due to the carbon build up
    Frenchman
    Nov 2009
    south wales
    Its just coming up to 60k and has done mostly motoway miles which is usually better for diesels.
    Keep me posted as my dad is a retired mechanic so messing about with parts is no problem.
    Regular Member keithsimmo's Avatar
    in the engine compartment.
    Default Try This
    Hi Guys,
    Try this .. it work for me.
    http://www.vectra-c.com/forum/showpo...8&postcount=24
    Quote Originally Posted by keithsimmo View Post
    Resolved.
    Fault code was P2279.
    It was the Electrical Solenoid side of the EGR valve that was covered in corrosion after only Miles. A big Thank you to everyone who helped and special thanks to "Jon7278" for putting the How 2 together and "cdti 150 SRi54 est" for the handy PDF.
    Only took me an hour after work tonight to strip it down clean it and put it back together.
    Below is the "How 2" that I used and the links to the PDF doc.
    Jon7278 if we ever meet I owe you a few drinks. Thanks.
    In my appreciation of this site I'm now off to buy a vectra-c sticker for my window and print off some flyer's to put on other cars. If there was a donate button I'd probably donate to that too. Instead I'll give some money to charity for red nose day on Friday.
    Thanks again.
    Keith.
    I just found another great How 2 on cleaning the solenoid side of the EGR valve which is next on my list of things to do. Just wanted to share it with you.
    http://www.vectra-c.com/forum/showthread.php?t=45867
    And a handy little printable PDF too!
    http://www.vectra-c.com/forum/attach...7&d=1232829228
    Thanks in advance to "Jon7278" for putting the How 2 together and
    "cdti 150 SRi54 est" for the PDF.
    Regular Member Jezzy's Avatar
    S.E
    Here are the BHP and torque curves for the 150 BHP 1.9; BHP is on the left and torque is on the right; for both graphs look at the grey (lower) curve, as the blue curve is for a www.superchips.co.uk remapped engine.
  1. Replies: 17
    Last Post: 11th March 2015, 00:55
  2. Signum Sluggish low power, Limp mode at high power.
    By Bigg943 in forum Vectra C / Signum Troubleshooting
    Last Post: 6th June 2011, 18:55
  3. Signum Sluggish low power, Limp mode at high power.
    Last Post: 5th June 2011, 11:30
  4. Replies: 11
    Last Post: 7th January 2010, 17:50
  5. Power Steering Electrical Power Drain
    By AntB in forum Suspension, Wheels & Brakes
    Last Post: 1st November 2007, 16:03
