Results 1 to 3 of 3
Thread: Ticking noise when revving
    Regular Member Danialj32's Avatar
    Sep 2009
    Warrington
    Default Ticking noise when revving
    Get a strange ticking noise when I rev, coming from the dashboard it seems, goes with the rev count, faster ticking higher revs, slower ticking lower revs, any ideas?
    WGAF#5
    could be a pulley/belt rubbing catching = open the bonnet and get someone else to rev the car and you have a look/listen whilst there doing it -remember saftey first whilst doing it
    Worcs/Staffs/Westmids (ish)
    If your 100% certain it's inside as opposed to under the bonnet, then:
    I doubt these have mechanical RPM counters, so my guess is maybe a voltage regulator that controls some sort of mechanical device behind the dash (fans or similar), may have gone. This would mean RPM increasing the voltage supply to and possibly speed of the device.
    Or it could just be a loose part or component that becomes resonant through vibration from the engine.
  1. Air Intake noise when revving
    By sammyt in forum Troubleshooting
    Last Post: 11th May 2012, 07:06
  2. ticking noise when air con on.
    By philc1210 in forum Engine & Drivetrain
    Last Post: 30th July 2011, 20:42
  3. engine noise when revving..
    By morri76 in forum Vectra C / Signum Car Chat
    Last Post: 5th May 2010, 13:58
  4. Odd ticking noise
    By Big Sig in forum Engine & Drivetrain
    Last Post: 20th June 2009, 22:54
  5. Whistling Noise When Revving
    By Sean-2.2Direct in forum Engine & Drivetrain
    Last Post: 26th November 2008, 10:23
