Thread: 1.8 vvti engine noisy
    Regular Member videodoctor's Avatar
    Blackpool
    Default 1.8 vvti engine noisy
    I have a 1.8 vvti petrol Vectra and for the past couple of months the engine has started sounding more noisy than normal.Also if you come to a junction and its on a slight hill and you change down into 2nd and pull away from lowish revs the engine makes a loud grumbling sound.I have had the car from new so i know that i didn't used to make this noise.I took it in to the dealers but as usual they said that they couldn't fault it.In general the car starts and runs perfect(loads of power) and theres no engine management lights on the dash.It sounds to me like the manifold is slightly leaking but the dealers said they couldn't see anything.Any idea as to what i should do next.Has anyone else with a vvti engine had this problem?Help!
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    could the air box be touching the body causing a noise
    Oct 2007
    Shropshire
    Is it also noisy on start up? If so that is exactly how mine was and it just got worse until it needed a top-end rebuild. Noone wanted to rebuild the vvt so I put an astra engine in myself.
    If it is I would take it to vauxhall straight away and kick-up fuss. They found no problem with mine either at first....
    Regular Member barkzz's Avatar
    Quote Originally Posted by videodoctor View Post
    Heard about a few issues of this nature with this engine.
    Getting more rattley. In some instances, the cambelts have come off!
    My old mans is getting worse, and he has it booked in now
  1. noisy engine
    By sparkie in forum Engine & Drivetrain
    Last Post: 12th February 2012, 14:34
  2. Really noisy cdti engine
    By Shogun in forum Engine & Drivetrain
    Last Post: 8th January 2012, 22:12
  3. What is meant by 1.8 VVTI? is the vvti engine better or worse?
    By Deann in forum Vectra C / Signum Car Chat
    Last Post: 14th May 2011, 11:19
  4. Engine noisy after being run
    By Riches in forum Engine & Drivetrain
    Last Post: 26th July 2010, 21:09
  5. 1.8 VVTi engine, lack of power.
    By mikeopolo in forum Engine & Drivetrain
    Last Post: 23rd November 2008, 00:50
