Thread: Which brake pad
    North Wales
    Default Which brake pad
    Hi guys i went ot buy sum new rear pads for my 53 plate vectra 1.8 SRI.
    i have a choice of 2 either with a mouse trap on the bacj or without.
    any ideas how i can find out without removing the pad ??
    thanks alot
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    with, normaly as they slide over the caliper piston. you will need a wind back tool
    North Wales
    o ryt do they not just "push" back in ?? or is it a twist and push 1 ???
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    no, rear are twist and push clockwise, rearly hard with out the tool
    North Wales
    ok pal thanks alot !
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    ok..
    Regular Member carpet's Avatar
    Jul 2006
    TENTERDEN KENT
    According to EBC Brakes (where I obtain my pads from as they do standard and uprated types) you will require the ones with springs to grip the piston. Hope this helps and as Matt above a LOT easyer with the wind in tool.
    Nottinghamshire
    Quote Originally Posted by carpet View Post
    The old-style rear pads had a 3-sided clip that slotted into a recess that ran round the end of the piston as you describe.
    The new-style rear pads have a spring on the outside edge instead that braces the inside pad against the inside of the caliper - there's no attachment to the piston.
    Many online catalogues list both types.
    Definitely go for a proper piston wind-back tool for the rear brakes - much cheaper than new calipers if you stripor jam the thread.
  2. Brake Warning light and display error message , BUT BRAKE LIGHTS ARE WORKING FINE
    By JACKALG1 in forum Electrical & ICE (including SatNav)
    Last Post: 24th May 2013, 18:56
  3. brake help please
    By sristeven1 in forum Suspension, Wheels & Brakes
    Last Post: 20th September 2010, 18:30
  4. yellow brake calliper brake set
    By The Gas Man in forum Parts for sale
    Last Post: 22nd July 2010, 22:41
  5. What brake pads for 2.8 V6 Signum??? 314mm brake discs
    By luke4487 in forum Suspension, Wheels & Brakes
    Last Post: 25th February 2010, 23:21
