Results 1 to 10 of 14
Thread: Fans not working on 1 2 & 3
    Jul 2009
    Peterlee
    Default Fans not working on 1 2 & 3
    Replaced resistor pack, changed pollen filter, unblocked drain dry as a bone, fan spins freely and work on no4. But still not working on 1,2 & 3. I tried the new resistor pack in the harness hanging out and not in the blower will it matter am getting really ****** of with it now. PLEEEEAAASE help me
    WGAF#5
    might be the resistor pack was not only burnt out but also taken the fan unit with it -
    Jul 2009
    Peterlee
    Question
    But would'nt that mean the fan wouldn't work at all? Just guessing here, is there more electric parts in the fan unit mate?
    WGAF#5
    the fans are controlled by the resistor pack - but may be that the fastest speed is all the unit has left
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    you need to have the resistor fitted in place bud
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    chuck one in, it'll be fine
    Regular Member Chocki's Avatar
    Jul 2006
    Wolverhampton
    There is also a relay which is prone to failure, cant remember the relay number but its located behind the panel accessible when you open the passenger door.
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    the fan works its just the resitor has gone open circuit
    Jul 2009
    Peterlee
    Quote Originally Posted by Chocki View Post
    took the panel off like you said, and your right there are a load of fuses behind there, and one big orange fuse, but wouldn't have a clue which is which as there are no numbers or a diagram. Cheers mate will investigate....
    Regular Member 67688c's Avatar
    Apr 2008
    In UK
    There was a extensive thread on this problem a while ago, it also contained some images of the electrical circuit for the fan speed control which I uploaded for the member who was having the issues, showing all the relays etc. In that members case only certain fan speeds were working. He had already changed the resistor pack, and in his case it turned out to be a relay.
    So it may be worth while doing a search for the thread.
  1. Fans not working!
    By Danwells72 in forum Vectra C / Signum Car Chat
    Last Post: 20th July 2012, 20:37
  2. radio working, not working, working again
    By J P S in forum Electrical & ICE (including SatNav)
    Last Post: 22nd February 2012, 00:59
  3. heater fans not working?
    By Jaspa in forum Electrical & ICE (including SatNav)
    Last Post: 2nd December 2011, 23:06
  4. Replies: 0
    Last Post: 10th November 2011, 22:58
  5. Engine Cooling fans working correctly?
    By luke4487 in forum Engine & Drivetrain
    Last Post: 28th April 2011, 11:15
vectra c glovebox relay diagram
