Results 1 to 3 of 3
Thread: Cd 30 radio info
    Oct 2009
    S Wales
    Default Cd 30 radio info
    Just had a new radio fitted under warranty. Can anyone tell me what are the functions, I think , called SDVC 1through to 5. I haven't got the radio manual. I want to radio to stay on when the engine is switched off and not start automatically when I start the car.
    One a differant note, what MPG would you expect to get out of a 1.9 cdti 120 if driven normally.( Not booting it) Is 40 about average urban driving?
    Thanks in advance.
    Regular Member RobW's Avatar
    Tain - Easter Ross
    PM me you address, I have a spare CD30 manual I can post to you. There are options to sort out the key logic and is SDVC Speed Dependant Volume Control? ie, the volume goes up when the speed goes up.
    Full Member Robsey's Avatar
    North East Cheshire
    14 Post(s)
    Trim : Energy
    Mileage : 131,000
    SDVC is speed dependent volume control...factory standard is about 2
    This function increases the radio volume to compensate for louder engine and road noise at higher road speeds. 0 = no increase in volume at high speed...5 = max amount of volume increase at higher speeds
    To prevent automatic on/off switching
    turn your radio on, press settings and look for Ignition Logic control...
    Uncheck (remove the cross from the box) and this will then only turn the radio on /off when you press the power button.
    Regarding MPG...dependent upon driving style, load etc...you should expect between 40 to 44 mpg.
    My 1.9cdti (150) returns an average 44 mpg
  1. Replacing Board Info Display (BID) with Color Info display (CID)
    By grigs1 in forum Electrical & ICE (including SatNav)
    Last Post: 11th April 2012, 22:13
  2. Need info please
    By veccyjim in forum Vectra C / Signum Car Chat
    Last Post: 11th April 2010, 09:34
  3. date display on vectra info screen when turning on aftermarket radio?
    By svpworld in forum Electrical & ICE (including SatNav)
    Last Post: 3rd September 2007, 11:19
  4. PVS info
    By Andy in forum General Chat
    Last Post: 18th May 2006, 13:47
  5. Info please
    By big peachy in forum Vectra C / Signum Car Chat
    Last Post: 8th May 2006, 23:14
