Results 1 to 10 of 25
Thread: Instant steamy windows
    Regular Member gsi3.2Daveyg's Avatar
    Nov 2009
    Preston
    Default Instant steamy windows
    Hi
    I have a Vectra 3.2 and had a problem this morning, while overtaking a car on the motorway this morning, my windscreen just on the right side suddenly steamed up, and wouldn't clear even though i put full de-mist on,it just made it worse, plus there was a nasty exhaust smelly type smell came into the car through the vents, ive done all the checks, pollen filter bit dirty but not wet, drain hole clear, set climate at different temps, switch air con on, and nothing, any one else had this problem? seemed wierd only on right side. any suggestions please.....
    WGAF#5
    i take it you have dual zone climate control - one of the recirulation flaps will be stuck or the cog wheel may be damaged - you will need to strip the heater box to find out which
    Nov 2009
    Preston
    thanks for that, I suppose with that sad smilie its no easy task,
    Wales, UK
    mmm, Not sure but sounds like a bit of a mission on the Vec C...
    Regular Member old cruiser's Avatar
    slough
    Also check the drain hole on driver's side.
    Cheers Pete
    Nov 2009
    Preston
    thanks pete, is that in the cabin?? last night going home i risked turning up the temp from LO to HI, god, wish i didn't, steam came rising out of the screen vents, causing the screen to instantly steam up, not just that, it was like a greasy steam and hard to get off, wont do that again till fixed, has this happened to any of you guys?? is it easy to fix/diy or do i hold my hands up and let dick turpin (GARAGE) fix it, also went to buy an haynes manual, manual for vectra didn't cover 3.2 etc etc, !! typical, just my luck..
    Regular Member Pete B's Avatar
    Malvern
    Quote Originally Posted by gsi3.2Daveyg View Post
    Check your water level. Has it suddenly dropped at all or more than usual, even just a small amount.
    A small leak in the heater radiator (or pipes to it within the air circulation area) may cause this, I had it happen on a different (non Vx) car. As water from this source will contain antifreeze, this element may cause the smell/greasiness.
    WGAF#5
    yep it may be the heater matrix leaking coolant into the heating system from the description of what your saying
    Mileage : 000
    Yes if there was steam. It does sound like you have a heating/cooling system problem.
    Nov 2009
    Preston
    thanks guys , had a look at coolant level doesn't look like its moved, but i did switch off straight away, and i'll take that the heater matrix is behind dash from what i've read from other threads, will mine be accessible through glove box?
  1. steamy windows
    By jamiedvvt in forum Vectra C / Signum Car Chat
    Last Post: 16th November 2012, 08:16
  2. steamy windows
    By hippo in forum Vectra C / Signum Car Chat
    Last Post: 20th January 2011, 18:36
  3. Steamy Windows
    By ballmonkey in forum Vectra C / Signum Car Chat
    Last Post: 20th January 2008, 20:51
  4. Steamy windows
    By Baldy in forum Bodywork & Interior
    Last Post: 12th January 2008, 20:35
  5. Steamy windows!
    By scott_150cdtisri in forum Bodywork & Interior
    Last Post: 21st December 2006, 20:13
