Thread: Help in servicing a 1.9cdti/150
    Kingston Upon Hull
    Default Help in servicing a 1.9cdti/150
    Hi All can anyone give me some tip's about servicing my car
    IE what is the best oil to use?
    do i need to fill the fuel fillter before fitting a new one
    is it hard to do on ramps and a jack
    these are the sort of things i need to know
    Thanks for any help
    Graham
    Kingston Upon Hull
    No one service there car on here ? do you take them all to the MAIN DEALERS ?
    i thought a lot of people on here would do there own cars !!!!
    Administrator plasma's Avatar
    On the Forum
    398 Post(s)
    Engine : 150
    Mileage : 74000
    use 5/30 GM oil normally, but on my work one i use 10/40 as i changed it over 10k
    Air filter, pollen filter (when needed), oil filter, (fuel filter every 20k or so).
    TO change fuel filter you need to remove it and put it in a vice or somewhat to get a grip to undo the lid, no need to refill it afterwards as the diesel pump fitted in the tank will pump diesel into it and purge the air. May need a few key turns to do it.
    Mines all done off the axle stands for draining the oil, the oil filter is a pig to get at. I fit the socket on from underneath with the ratchet attached then lean over the engine to get to it as access to turn it from underneath is non-existant
    Sep 2009
    Swindon
    To add the that, I would get a copy of the haynes manual to use as reference and also for torque settings. There are quite a few how 2 on the site here also like how to replace brake fluid, clean the EGR etc.
    I agree about the oil filter easy to make a mess with where it is situated, just make sure you use axel stands or ramps if under the car and keep safe
    Frenchman
    Feb 2007
    North west
    worth buying a new sump plug gasket before you start - cant usually re use them.
    On the Forum
    398 Post(s)
    Engine : 150
    Mileage : 74000
    maybe worth investing in a spare sump plug too in case it starts to round off whilst removing it.
    Kingston Upon Hull
    Thank's for the help please keep them coming more help the better
    thankyou Graham
  1. vectra 1.9cdti and astra 1.9cdti clutch
    By abz123 in forum Vectra C / Signum Car Chat
    Last Post: 13th October 2012, 21:01
  2. 1.9cdti 150 Servicing Help Please!!
    By john506 in forum Diesel Engine related
    Last Post: 14th May 2011, 22:00
  3. GSi servicing.
    By Hyperhart in forum Vectra C / Signum Car Chat
    Last Post: 17th July 2010, 21:45
  4. Servicing
    By VECTRAMAN in forum Vectra C / Signum Car Chat
    Last Post: 6th November 2007, 21:06
  5. Servicing
    By Hendry in forum Vectra C / Signum Car Chat
    Last Post: 20th January 2007, 17:52
