Results 1 to 10 of 22
Thread: Egr valve (again)
    Nov 2009
    Warrington
    Default Egr valve (again)
    Eh up guys. Only a quick bit of advice please, i keep reading about problems with the egr valve on veccy cdti 150, is this just a poor design fault of the cdti engine? Have vx modified the part now or do u still get this part failing on newer models, i understand it is an easy job to clean/replace the part so not a major issue i suppose, just wanted some advice, cheers.
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Think you can get a blanking plate now
    Irmscher Insignia CDTI 130
    Cambridgeshire
    See here LINKY for part numbers from Fiat dealers mate
    Nov 2009
    Warrington
    sorry if this is a bit thick of me, when you say blanking plate do you mean this does away with egr valve?? how does this effect the engine not having the valve. am i right in saying the valve re circulates the exhaust gasses back into the engine, i fix boilers for a living so not totally stupid but dont have much knowledge about diesel engines.
    Cambridgeshire
    They are not really blanking plates. They restrict the flow of recirculated gases which in turn looks after the inlet manifold and egr valve. You cannot completely blank off the egr valve because the ECU will be looking for it and it will bring up fault codes. The only way it can be done it with a certain type of remap (can't remember which one does this )
    Regular Member robk6112's Avatar
    Halifax
    When I had mine replaced the garage said they had used a Saab one???
    Unsure though but it certainly goes better...
    Regular Member WeDesign's Avatar
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    Other than the EGR Valve and Third Injector Loom (both replaced in the last 15 months/10,000 miles) what else can cause no power below 2000 RPM?
    Cheers in advance
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    swirl flap rod fallen off
    Birmingham
    if that ok too then................
    Bye bye Vec B
    - Hello Siggy!
    Regular Member Chocki's Avatar
    Jul 2006
    Wolverhampton
    Anyone know how big the holes are in the modified blanking plate?, I would like to make my own using an old EGR as the template.
  1. Brake servo Valve (one way valve)
  2. Replies: 6
    Last Post: 29th July 2012, 13:52
  3. Egr valve, swirl valve problems etc..
  4. EGR valve / Swirl valve
    By SwavGav85 in forum Engine & Drivetrain
    Last Post: 5th January 2009, 17:17
  5. EGR valve and Swirl Valve
    By TUX-VECTRA in forum Vectra C / Signum Troubleshooting
    Last Post: 6th July 2007, 00:43
