Page 1 of 4 123 ... LastLast
Results 1 to 10 of 37
Thread: which diesel additive
    Regular Member wardy's Avatar
    Chichester
    Default which diesel additive
    I have a long trip comming up, and have been thinking of putting some fuel additive in the tank (one of the cleaning ones).
    Which one to go for?
    Its an 05 3.0cdti with 54,000 miles
    Ta
    Plymouth
    millers
    Sep 2009
    Glasgow
    2nd that millers, way better than redex.
    Regular Member Grimo72's Avatar
    Apr 2008
    Lincs
    3rd that millers
    oh and a italian tune up motorway always helps
    Regular Member signum03's Avatar
    worthing
    4th that millers!
    Sep 2009
    Glasgow
    what have i started could be a long night
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    I'm never ever ever ever adding an injector cleaner in my 3.0CDTi again!
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Yep millers diesel sport 4, I always use it, cleans the fuel system and raises the cetane number of the diesel to give more power. A bottle lasts for ages too
    Quote Originally Posted by wardy View Post
    No matter how long the journey, it makes virtually no difference to the performance or economy
    Equally, if you drive at a constant 70mph then the engine will return its best economy, compared to general day to day drivng
    Have the original SCVs been replaced?
    If so, then no additives are required
    If not, then you may want to consider an additive that "claims" to lubricate the fuel pump, avoid injector cleaners
    I am currently waiting a response about the change in diesel on forecourts since 2004
    The Y30DT engine was designed around the diesel in supply in 2004, however by 2005 the sulphur content had been removed
    http://www.med.govt.nz/templates/Page____10375.aspx
    http://www.bp.com/liveassets/bp_inte...arineUsers.pdf
    As you can see in the above, "The last of these effects is detrimental to injector pumps that rely on the fuel to lubricate their moving parts", then read the secton on "Seal shrinkage"
    Sulphur has been reduced, but what additive is available to compensate for this?
    Sulphur is down from 500ppm to 15ppm
    Equally, if my calculation is correct then you could add millers products, but check the technical data sheet
    Plymouth
    Just curious... could the change in Suplhur content contribute to the reasons why so many Injector seals go on the diesel engines?
  1. bg224 additive
    By wildchild in forum General Motoring Chat
    Last Post: 19th February 2013, 21:51
  2. Which engine oil additive have you used?
    By kentish_bloke in forum Tuning
    Last Post: 5th June 2011, 18:31
  3. Oil additive
    Last Post: 3rd October 2010, 22:19
  4. Millers Diesel Additive
    By WeDesign in forum Diesel Engine related
    Last Post: 3rd March 2010, 20:48
  5. Diesel Additive for Vectra C Estate
    By Stringer in forum Vectra C / Signum Car Chat
    Last Post: 7th February 2008, 18:06
